Page 8 of 8 FirstFirst ... 45678
Results 71 to 74 of 74
Thread: Feeling lucky, is the 3c509B compatible with 8088 using NE1000 drivers?
  1. #71
    6,150
    Quote Originally Posted by fsikkerm View Post
    Petty that just is not possible with 3c5x9cfg configure /i:7 on the ibm
    Did you try? I thought 3c5x9cfg did actually work on an 8088, but I could be wrong. If the program starts up, that should be enough, although you might want to remove other non-essential cards (sound card, serial ports, etc.) to reduce the possibility of the program getting confused.
  2. #72
    3c5x9cfg never worked for me on my v20 tandy 1000sx. had to set mine up on my 486. once setup tho the card runs fine.
  3. #73
    Nov 2019
    Boskoop the netherlands
    5
    Cool
    It started and under dos 5.0 even got the menu, but message No Nics founds..
    So just an hour ago I wend to my friend and hooked the card in a Pentium one with Isa .. Card recognized and I have set the IRQ to 7
    Work like a charm now
    Now on to set a HyperV linux and gone try
    ETHERDFS - THE ETHERNET DOS FILE SYSTEM
    http://etherdfs.sourceforge.net
    So all thx for the helpfull info..
  4. #74
    6,150
    Glad you got it working!
    ETHERDFS uses custom frames that don't seem to work over wireless bridges, so you'll need to connect both source and destination with wired cable.
