Results 1 to 10 of 15
Thread: Sun Server Video (lack of)
    Default Sun Server Video (lack of)
    I just got my sun to VGA adapter today. So I plugged it in, no keyboard yet, and no video is displayed. Tried both machines. Is this because the keyboard is not plugged in? I've heard about things like this.
    Robert
    Nevermind, keyboard has to be plugged in even if the monitor is. I thought it was one or the other. But keyboard comes today, crosses fingers.
    Exactly. No keyboard = server assumes it's headless and defaults to serial port a.
    Grr, still no signal on both servers. Looks like I'll have to try a new monitor.
    Oct 2011
    Durham, Durham, United Kingdom
    106
    Does the monitor do sync on green? IIRC, the sun 13W3 connector outputs the sync signal that way, same as SGI (though on a different pinout).
    Yeah the light turns green, on the monitor. Then starts to blink.
    Oct 2011
    106
    No, I meant does you monitor support sync-on-green signal: http://en.wikipedia.org/wiki/Sync_on_green
    VGA uses seperate horizontal and vertical sync lines - a lot of workstations (eg SGI and Sun) use a single, combined sync signal embedded in the green video line, and this is quite common on the 13w3 video connector - Not all monitors support this.
    Some Sun video options have horizontal and vertical sync lines (meaning they're compatible with VGA displays), but I don't know if all of them do.
    I think my problem is that its an old vga monitor. The resolution is pretty high for sun servers I have heard. I also tried to run the servers via serial cable. But all I have is a 25 pin to 9 pin modem cable. I think I may need a null modem cable. Sigh* This is my first time trying to use sun hardware or server stuff.
    30,323
    Some higher-end VGA monitors support SOG and usually can be recognized by the 5 BNC connectors on the unit.
    e.g. NEC AccuSync
    The PS2 community generally knows about SOG monitors, so it's worth asking over there.
    Feb 2011
    2,033
    10
    Haven't you a modern SVGA mon itor to try? When you get the serial port working you can wind the display size back on the SUN. Intel servers are OK. Whenever I need to get the Console on one of the SUN servers at work I end up pathcing it to the serial port on the Windows/2003 server above or below it in the rack and using Hyperterm. Sadly the new Intel boxes don't have seial ports so I am going to need a USB to Serial adaptor...
    G4UGM
