Page 1 of 23 1234511 ... LastLast
Results 1 to 10 of 229
Thread: commodore 4016-n with extreme water damage
    Dec 2004
    UK, Surrey
    585
    3
    Default commodore 4016-n with extreme water damage
    I got a commodore 4016-n with extreme water damage cheap on ebay, I want to repair and mod it to make it useful,
    I could do with some info on making a hardware and software 40 / 80 column switch +ROMs
    CRT circuit diagrams
    and commodore high resolution graphics board 512x512 pixels, I want to buy or build one
    I have the ram to upgrade the system to 32k and 4 video ram chips
    the keyboard was damaged so I could rely do with borrowing a space bar, return and shift keys for me to copy
    Dec 2004
    UK, Surrey
    585
    3
    when I got the commodore 4016-n it had about 14 keys missing and when I moved it loads of rush pored out the case and part of the plastic crt surould was broken and missing, it luckly it hadent been powerd up and the internal fuse is ok
    Dec 2004
    UK, Surrey
    585
    3
    here are some pics
    it got the sticker becos the earth had come out the plug!
    Dec 2004
    UK, Surrey
    585
    3
    Default rusty crt
    all the steel work was rusty, I managed to take it apart and scrubed it all with steel wool and then dryed and seald the worsed in eboxy and wood vanish,
    Dec 2004
    UK, Surrey
    585
    3
    Default more pics of the rusty crt flame
    lots of rust!
    Dec 2004
    UK, Surrey
    585
    3
    Default more rust, but pcb is ok!!!
    the CRT pcb is basically ok but need new diodes as the old ones have been badly corroded?
    Dec 2004
    UK, Surrey
    585
    3
    Default keyboard
    I have taken the keyboard apart and cleaned it, it is missing a lot of keys so I have been casting copy's of the ones I have, but I could do with borrowing a space bar, enter, and shift key to copy, the keyboard will never look prity but I will get it working, I will add some pics later
    Dec 2004
    UK, Surrey
    585
    3
    I have also scrubed the mother board in the sink with shower gell and water then went over the remaining bits with acetone and cotton wool buds, it looks good now, all I have to do is replace all the corroded ic sockets and the rusted nuts and bolts, the regulators where very rusty, I cleaned up the contact ears and sealed the rust in withe wood varnish,
    Dec 2004
    UK, Surrey
    585
    3
    Default psu and m/b
    I am going to replace all eletolitic caps and put some safety's on the psu, eg fuses and over-voltage protect, I will need new roms and the old ones will probly go bad if they havent by now, I want to fit roms not eproms so they will never go bad.
    I will add more pics and info as I go along
    Dec 2004
    UK, Surrey
    585
    3
    any one want to help bring this very sad commodore 4016 back to life as a commodore 8032?
