Results 1 to 3 of 3
Thread: How Do You Clean Grimy Metal and Circuit Boards?
    Default How Do You Clean Grimy Metal and Circuit Boards?
    Hello Everyone,
    I have an Amiga 2000 that I'd like to clean up and I was wondering if anyone had a solution to that stuck on grim you get on circuit boards and chassis over time.
    Mike
    27,839
    For mild stuff, isopropyl alcohol will clean much of it off. Most circuit boards will withstand soap-and-water cleansing--be sure to dry them.
    Beyond that, it depends. I've cleaned a half-inch of mouse feces and urine off of circuit boards using oven cleaner after nothing else would touch it. Worked just fine, but the board had no aluminum parts on it.
    On metal, if things are really greasy and a mild cleaner such as Windex doesn't touch it, mineral spirits will generally get stuff off.
    awesome..thanks Chuck. I'll let you guys know how it goes
