(Copied from Wikipedia; feel free to edit and add to this article, and then remove this notice.)
The Intel 80486 microprocessor (alias i486 or Intel486) was a higher performance follow up on the Intel 80386. Introduced in 1989, it was the first tightly[1] pipelined x86 design as well as the first x86 chip to use more than a million transistors, due to a large on-chip cache and an integrated floating point unit. It represents a fourth generation of binary compatible CPUs since the original 8086 of 1978.
A 50 MHz 80486 executed around 40 million instructions per second on average and was able to reach 50 MIPS peak performance.
The i486 was without the usual 80-prefix because of a court ruling that prohibited trademarking numbers (such as 80486). Later, with the introduction of the Pentium brand, Intel began branding its chips with words rather than numbers.
Background
The 80486 was announced at Spring Comdex in April 1989. At the announcement, Intel stated that samples would be available in the third quarter of 1989 and production quantities would ship in the fourth quarter of 1989.[2] The first 80486-based PCs were announced in late 1989, but some advised that people wait until 1990 to purchase an 80486 PC because there were early reports of bugs and software incompatibilities.[3]
Improvements
The instruction set of the i486 is very similar to its predecessor, the Intel 80386, with the addition of only a few extra instructions, such as CMPXCHG which executes the compare-and-swap atomic operation and the XADD which executes the fetch-and-add atomic operation returning the original value, unlike the ADD instruction that only returned some flags.
From a performance point of view, the architecture of the i486 is a vast improvement over the 80386. It has an on-chip unified instruction and data cache, an on-chip floating-point unit (FPU), except in the SX and SL models, and an enhanced bus interface unit. Simple instructions (such as ALU reg, reg) execute in one clock cycle. These improvements yield a rough doubling in ALU performance over the 386 at the same clock rate. A 16-MHz 486 therefore has a performance similar to a 33-MHz 386, and the older design has to reach 50 MHz to be comparable with a 25-MHz 486 part.[4]
Differences between i386 and i486
  • An 8 KB on-chip (level 1) SRAM cache stores the most recently used instructions and data (16 KB and/or write-back on some later models). The 386 had no such internal cache but like the i486 supported a slower off-chip cache (level 2 cache).
  • Tightly coupled pipelining allows the 486 to complete a simple instruction like ALU reg,reg or ALU reg,im every clock cycle. The 386 needed two clock cycles for this.
  • Integrated FPU (disabled or absent in SX models) with a dedicated local bus; together with faster algorithms on more extensive hardware than in the i387, this gives faster floating point calculations compared to the i386+i387 combination.
  • Improved MMU performance.
The 486 has a 32-bit data bus and a 32-bit address bus. This required either four matched 30-pin (8-bit) SIMMs or one 72-pin (32-bit) SIMM on a typical PC motherboard. Just like the 80386, the 32-bit address bus of the 80486 enabled up to 4 gigabytes of memory to be directly addressed using a flat memory model with 32-bit linear addresses in protected mode. Just as with the 80386, the ability to use memory directly without segmentation helped performance in compliant operating systems and applications.
Models
  • Intel RapidCAD: a specially packaged Intel 486DX and a dummy floating point unit (FPU) designed as pin-compatible replacements for an Intel 80386 processor and 80387 FPU.
  • i486SL-NM: i486SL based on i486SX
  • i487SX: i486DX with a slightly different pinout sold as an FPU upgrade to i486SX systems; it was widely documented that an i487SX when installed completely disabled the existing i486SX on the motherboard, replacing it.
  • i486 OverDrive: i486SX, i486SX2, i486DX2 or i486DX4. Marked as upgrade processors, some models had different pinouts or voltage handling abilities from 'standard' chips of the same speed stepping. Fitted to a coprocessor or "OverDrive" socket on the motherboard, worked the same as the i487SX.
The specified maximum internal clock frequency (on Intel's versions) ranged from 16 to 100 MHz. The 16 MHz i486SX model was used by Dell Computers.
One of the few 486 models specified for a 50 MHz bus (486DX-50) initially had overheating problems and was moved to the 0.8 micrometre fabrication process. However, problems continued when the 486DX-50 was installed in local bus systems due to the high bus speed, making it rather unpopular with mainstream consumers as local bus video was considered a requirement at the time, though it remained popular with users of EISA systems. The 486DX-50 was soon eclipsed by the clock-doubled i486DX2 which instead ran the CPU logic at twice the external bus speed.
More powerful 486 iterations such as the OverDrive and DX4 were less popular (the latter available as an OEM part only), as they came out after Intel had released the next generation P5 Pentium processor family. Certain steppings of the DX4 also officially supported 50 MHz bus operation but was a seldom used feature.
Other makers of 486-like CPUs
486 compatible processors have been produced by other companies such as IBM, Texas Instruments, AMD, Cyrix, UMC, and SGS Thompson. Some were clones (identical at the microarchitectural level), others were clean-room implementations of the Intel instruction-set. (IBM's multiple source requirement is one of the reasons behind its x86-manufacturing since the 80286.) The 486 was, however, covered by many of Intel's patents covering new R&D as well as that of the prior 80386. Intel and IBM have broad cross-licenses of these patents, and AMD was granted rights to the relevant patents in the 1995 settlement of a lawsuit between the companies.[5]
AMD produced several clones of the 486 using a 40 MHz bus (486DX-40, 486DX/2-80, and 486DX/4-120) which had no equivalent available from Intel, as well as a part specified for 90 MHz, using a 30 MHz external clock, that was sold only to OEMs. The fastest running 486 CPU, the Am5x86, ran at 133 MHz and was released by AMD in 1995. 150 MHz and 160 MHz parts were planned but never officially released.
Cyrix made a variety of 486-compatible processors, positioned at the cost-sensitive desktop and low-power (laptop) markets. Unlike AMD's 486 clones, the Cyrix processors were the result of clean-room reverse-engineering. Cyrix's early offerings included the 486DLC and 486SLC, two hybrid chips which plugged into 386DX or SX sockets respectively, and offered 1 KB of cache (versus 8 KB for the then-current Intel/AMD parts). Cyrix also made "real" 486 processors, which plugged into the i486's socket and offered 2 or 8 KB of cache. Clock-for-clock, the Cyrix-made chips were generally slower than their Intel/AMD equivalents, though later products with 8 KB caches were more competitive, if late to market.
The Motorola 68040 (best known for its use in the Macintosh Quadra series), while not compatible with the 486, was often positioned as the 486's equivalent in features and performance; however its performance lagged behind production 486 systems. The 486 had the ability to be clocked significantly faster without suffering from overheating problems. For a time Apple attempted to compete with Intel's clock doubling 486DX2 systems by publicizing misleading doubled clock rates for its '040-based Macintosh Performa systems, despite the lack of any clock doubling.
Motherboards and buses
Early 486 machines were equipped with several ISA slots (using an emulated PC/AT-bus) and sometimes one or two 8-bit–only slots (compatible with the PC/XT-bus).[6] Many motherboards enabled overclocking of these up from the default 6 or 8 MHz to perhaps 16.5 or 20 MHz (half the i486 bus clock) in a number of steps, often from within the BIOS setup. Especially older peripheral cards normally worked well at such speeds as they often used standard MSI chips instead of slower (at the time) custom VLSI designs. This could give significant performance gains (such as for old video cards moved from a 386 or 286 computer, for example). However, operation beyond 8 or 10 MHz could sometimes lead to stability problems, at least in systems equipped with SCSI or sound cards.
Some motherboards came equipped with a 32-bit bus called EISA that was backward compatible with the ISA-standard. EISA offered a number of attractive features such as increased bandwidth, extended addressing, IRQ sharing, and card configuration through software (rather than through jumpers, DIP switches, etc.) However, EISA cards were expensive and therefore mostly employed in servers and workstations. Consumer desktops often used the simpler but faster VESA Local Bus (VLB), unfortunately somewhat prone to electrical and timing-based instability; typical consumer desktops had ISA slots combined with a single VLB slot for a video card. VLB was gradually replaced by PCI during the final years of the 80486 period. Few Pentium class motherboards had VLB support as VLB was based directly on the i486 bus; it was no trivial matter adapting it to the quite different P5 Pentium-bus. ISA persisted through the P5 Pentium generation and was not completely displaced by PCI until the Pentium III era.
Late 486 boards were normally equipped with both PCI- and ISA-slots, and sometimes a single VLB slot as well. In this configuration VLB or PCI throughput suffered depending on how buses were bridged. The VLB slot in these systems was usually only fully compatible with video cards (quite fitting as "VESA" stands for Video Electronics Standards Association); VLB-IDE, multi I/O, or SCSI cards could have problems on motherboards with PCI slots. The VL-Bus operated at the same clock speed as the i486-bus (basically being a local 486-bus) while the PCI bus also usually depended on the i486 clock but sometimes had a divider setting available via the BIOS. This could be set to 1/1 or 1/2, sometimes even 2/3 (for 50 MHz CPU clocks). Some motherboards limited the PCI clock to the specified maximum of 33 MHz and certain network cards depended on this frequency for correct bit-rates. The ISA clock was typically generated by a divider of the CPU/VLB/PCI clock (as implied above).
One of the earliest complete systems to use the 80486 chip was the Apricot VX FT, produced by United Kingdom hardware manufacturer Apricot Computers. Even overseas in the United States it drew attention as "The World's First 486" in a popular September 1989 issue of Byte magazine (shown right).
Later 486 boards also supported Plug-And-Play, a specification designed by Microsoft to make component installation easier for consumers that began as a part of Windows 95.
Gaming
The 486DX2 66 MHz processor was popular with many players of video games during the early to mid 1990s, toward the end of the MS-DOS gaming era.[citation needed] It was often coupled with a VESA Local Bus video card.
The introduction of 3D computer graphics spelled the end of the 486's reign, because 3D graphics make heavy use of floating point calculations, need faster CPU cache and more memory bandwidth. Developers began to target the P5 Pentium processor family almost exclusively with x86 assembly language optimizations (e.g., Quake) which led to the usage of terms like "Pentium compatible processor" for software requirements. Many of these games required the speed of the P5 Pentium processor family's double-pipelined architecture.
Obsolescence
The AMD Am5x86, up to 133 MHz, and Cyrix Cx5x86, up to 120 MHz, were the last 486 processors that were often used in late generation 486 motherboards with PCI slots and 72-pin SIMMs that are designed to be able to run Windows 95, and also often used as upgrades for older 486 motherboards. While the Cyrix Cx5x86 faded quite quickly when the Cyrix 6x86 took over, the AMD Am5x86 was important during the time when the AMD K5 was delayed.
In the general purpose desktop computer role, the 486s were used as budget machines for people who could not afford the latest computers, until around 2001, when Windows 95 support ended and Windows 98, ME, 2000, and XP required much more powerful computers to perform well.
Although the 486 became obsolete for personal computer applications by the mid-1990s, Intel had continued production for use in embedded systems. In May 2006 Intel announced that production of the 80486 would stop at the end of September 2007.[7]
