Page 8 of 11 FirstFirst ... 4567891011 LastLast
Results 71 to 80 of 108
Thread: MicroPDP-11 - some questions
  1. #71
    Still no luck figuring this out. Does anybody have any idea what's going on here? I kind of suspect the OEM bootstrap theory, and I'm up for getting a couple EEPROMs and trying it with a known-good set, but the 11/73 firmware images on Bitsavers are 2x16KB, and according to the manual the MXV11 only supports up to 2x8KB...
  2. #72
    Aug 2012
    California
    140
    Looks like you change the ROM size with jumpers on it:
    prom size J50-J51 J49-J51
    none
    2K x 8 R R factory default
    4K x 8 R I
    8K x 8 I I used with MXV11-B boot roms *
    J20-J21 specifies 2K user UVROMS (2716) directly addressed
    J20-J19 specifies 4K or 8K ROM directly addressed.
    Note J21 is a +5V post
    Caution to use the MXV11-B diagnostic boot rom set the
    jumpers noted with * must be selected (J-15-J17,J50-J51,
    and J49-J51) as well as the boot mode option of J44-J45
  3. #73
    Yes, but there's no setting for 16K x 8 ROMs, which is what these are. Unless that's not the MXV11-B ROM?
  4. #74
    Aug 2012
    California
    140
    Ya those can't be right but, I found them for you. I can't post urls so, I'll PM the address to you
  5. #75
    Dec 2010
    Seattle, WA
    1,758
    The 16KB images are for the KDJ11-B M8190 11/73.
    For the MXV11-B you use the 8KB images.
    http://www.dunnington.u-net.com/public/DECROMs/ROMlist
  6. #76
    Thanks so much. I'll give those a try as soon as I get my hands on a couple suitable EEPROMs.
  7. #77
    Dec 2010
    Seattle, WA
    1,758
    You can get 68766 EPROMs for $8 each at http://www.unicornelectronics.com but there is also a minimum order amount, maybe $25.
    You can sometimes find better deals for them on eBay. I don't see any listed currently. I have a handful myself which I got on eBay a while back.
  8. #78
    Unicorn Electronics is great except for that order minimum. But I'd rather go with EEPROMs anyway as I don't have a UV eraser; I got a couple from Jameco, so hopefully I'll be able to get this figured out by next weekend.
  9. #79
    Dec 2010
    Seattle, WA
    1,758
    Is there an 8KB EEPROM part with the correct pinout for the MXV11-B?
    I wasn't aware of any suitable reprogrammable 8KB parts other than the MC68766.
    Opps. I was thinking of the 24-pin sockets on the M8189 KDF11-B 11/23-Plus, where I have used 8KB MC68766 parts.
    I just looked at my MXV11-B and I do have a pair of much more common 28-pin 8KB EPROM parts installed.
  10. #80
    Mar 2008
    Westchester County, NY
    1,225
    Gents,
    Check this out: http://www.vintage-computer.com/vcfo...achmentid=2719
    You'll see how I got around not having 68766s when I wanted to upgrade an 11/23+.
    Lou
