Thread: Wang PC
    Default Wang PC
    I recently moved. With that I found my old Wang PC circa 1987.
    I connected the cables, plugged it in and flipped the switch.
    I whined and wirred and the monitor came to life.
    Go to enter the date. The 1 key didn't work. Next the enter and execute keys didn't work.
    Any suggestions? Or do I have an anchor?
    I suggest you stop playing with your old Wang.
    Jan 2012
    Surrey,BC,Canada
    148
    Do you have another AT keyboard to try. IIRC, the cable ends matches the AT plug.
    Jan 2005
    1,510
    goofy Wang commercial from Australia:
    https://www.youtube.com/watch?v=QOUwzzSQz7c
    You should be more specific. Yes 1987 is too late for *the* Wang PCs, early IBM incompatibles. But when I see "Wang PC" I think of them.
    I have one of the 386 based units, found on the side of the road w/a PC/AT. No k/b though, so I can't offer any specific help. All I know is 1 or both has financial data from IIRC Chase bank. Maybe someone was doing work from home. Think I've found machines w/sensitive data? Probably not.
    Y'all should stop dissing Mr. Wang and others w/the same name.
