Results 1 to 10 of 10
Thread: IBM XT Hardrive
    Default IBM XT Hardrive
    I have an IBM XT pc, and the Hard drive appears to be broken, it says "Boot disc error".
    Is there anywhere I can get new discs from, or is it possible to to just connect a normal IDE drive, or make a new cable?
    I'm pretty good at soldering etc, so making a cable would not be too much of a problem.
    (Damn, you know you can type fast if you can add 2 threads in less than 2 minutes! )
    If you want to get an old 10-20MB drive, for authenticity I guess, you should check out a local electronics surplus (if there's one near you that is... )
    http://trs80hack.ytmnd.com/ YTMND: TRS-80 Hacking Secrets Revealed!!!
    There are 10 types of people in this world: Those who understand binary, & those who don't.
    http://mtac.profusehost.net/
    http://mtac.profusehost.net/forum/index.php
    Heh, it was great to find this forum, my google skills aren't quite up to finding the information I need. I am quite a fast typer though...
    I have looked round the old computer shops, and on ebay, but I live in the UK and for some reason they don't seem to love old pcs as much as I do.
    I'm willing to pay shipping and some money if some lovely american wants to send one to me, heh.
    Anywho, have you opened up your XT, & made sure everything's set up right? No loose cables, displaced or incorrectly set Jumpers, something plugged in backwards?
    Also, will MS-DOS recognize the disk? Have you tried using FDISK & Format on it? (I think to format it as a system partition it's "format c: /s", but I haven't done it in a while, so I can't be sure)
    I've had a look inside, I'll do what you said once my exams are over. Yay for GCSEs
    Also, remember that repartitioning & reformating a HD will lose all data on it, so if it's a computer you've had for 20+ years & want to recover data, doing the above would be a bad idea. Before doing anything, just try reading from it in MS-DOS & see what's on it if anything, & if anything important, be sure to back it up!
    Random fact of the day: An Apache/2.0.46 system can be crashed by sending an HTML request to port 443.
    Also see thread 'Seagate ST-412', you might found solution there.
    Most reasonable idea came to my mind: Maybe it don't have OS installed?
    Most people before selling computer format disk or delete important data.
    You shouldtry to acces drive from diskette. If it fail try SpeedStor utillity.
    I had a chat with my dad, and apparently there's a pc museum near where he works so he's going to take it in and let them have a look-see.
    It did have an OS at one point, some form of DOS becuase we used to run old games on it.
    Nov 2003
    London, England
    1,344
    You don't NEED a hard drive to run an XT, if you have a boot disk, you can boot DOS from a floppy disk.
    If you do find a supply of MFM drives in the UK, please let me know! Judging by the strange sounds from my ST-412, it's going to need replacing...
    You should park heads of hard drive before moving it...
    My ST-412 still don't work propetly...
