Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: New additions - TRS-80 Model IIIs
    Thanks for the input guys. I'll have to take another look at the PSU, but I don't recall seeing any extra holes. Even if there aren't any, I'm sure the trace is wide enough to have a new hole drilled to fit the smaller lead spacing - at least that way I can stick to the original spec.
    CP/M-86 Software Repository www.eolith.co.uk
    Send me a private message with your e-mail address and I'll send you a capacitor if I have one. I'll look at a model III power supply this weekend and check.
    Quote Originally Posted by Old Thrashbarg View Post
    If the board has alternate mounting holes for a different sized cap, then great, problem solved...
    Well, I was pleasantly surprised to find there were alternate mounting holes under the old capacitors. They weren't visible on the trace side as solder had flowed over them. Anyway, I've now got one working model III (well at least tested working under rom basic).
    I'll take a look at the other machine over the weekend and then have a go at producing some boot diskettes.
