Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
Thread: UNIX for a 486?
    Default UNIX for a 486?
    My 486 system is a Compaq prosignia vs with a 486dx2/66, 96 megs of ram, and 1gb SCSI drive on a Adaptec 1540cp isa card. Right now it runs FreeBSD 3.3, but I'd like to get back to something more traditional (like sysV). Does anyone know where I could come up with disks or images that would play nicely with my config?
    Thanks -- TN-048
    Sep 2011
    Nova Scotia, Canada
    24
    I'm building a similar box, only with an IDE drive, and a whole lot less memory... Xenix, PC-IX (Interactive), AT&T SVR4, or MicroPort should work nicely. I'll send you a PM with some additional info
    Do you plan on having networking networking? I have a 3c509 but I have no idea if it'll work with svr4 (which is the one I want to use). Any ideas?
    Sep 2011
    Nova Scotia, Canada
    24
    Actually, I think I've got the same NIC - Etherlink III 3C509B... I haven't tried it yet, but I suspect it will work in AT&T
    Dec 2012
    Las Vegas NV
    135
    My news years resolution is to get my 468/133 with SCO Unix 3.2 v4.2 off the floor and on the home network by Friday . Personally, either SCO or ISC (Interactive) 4.11 is a great choice. The only problem with the SysV Unices is making sure you have all the packages. Base packaging didn't include networking/development/etc. A work around solution is to hook up UUCP with a Serial to Ethernet connection of some type.
    Geoff
    34,970
    FWIW, earlier NetBSD releases trend pretty close to the BSD 4.3+ releases and are a lot easier to get drivers for. I felt right at home on a a NetBSD 3.x distro.
    Actually, I think I've got the same NIC...
    -- Yeah that is exactly my nic.
    I will try out NetBSD if I can't get any of the more "classic" Unices working.
    I got home for a while to try AT&T SVR4, just to find that it doesn't like my scsi card. I'll be trying microport SysV when I get home from work.
    New Zealand
    4,167
    4
    Quote Originally Posted by gepooljr View Post
    Geoff
    It is Friday
    lmao.. darn time travelers. I'm pretty sure as long as it has support for an NE2000 NIC you'll be fine. 3com was a pretty good standard back then, I'm just not sure about the age of the card vs OS or if it'd be expecting a token ring or arcnet or something. But certainly nothing wrong with giving it a go and finding out the fun way. You could also possibly get a result under an emulator if it uses an older nic emulation. I think the older (pre microsoft) Connectix VirtualPC used a 3com or ne2000 driver if I'm not mistaken.
    There's lots of SCO, Xenix, and other images on the net. WinWorld has many, but there are probably other sources.
