Results 21 to 30 of 39
Thread: IBM PC 5150 and IBM PC XT 5160 FAQ
  1. #21
    apologies if this question has come up. Were all 5150 motherboards brown? Were all 5160 motherboards green?
    or dark dark purple
    in my experience: 1981-1984 - green
    1984-1985 - brown
    1985-1987 - dark purple
    IBM PC 5150(A): IBM PC 5150(B): IBM PC 5160 (64-256k): IBM PC 5160 (256-640k): IBM PC 5170 (099): IBM PC 5170 (319/339): IBM PC 5140: IBM PC 5162: IBM PC 5155: IBM PC Expansion Unit 5161:
    WANTED!: IBM 5175 monitor, IBM 5145 monitor, IBM PC/XT/AT rear screws, Intel INBOARD 386AT card, IBM 5140 keyboard, very early IBM PC (S/N: under 5000)
    My IBM PC hardware collection
  2. #22
    Whats the purpose of this hole?
    I know that on XT-286 serve it for battery pack, but i have it also on my early XT case (05/1983) and i guess that in 1983 nobody think about batteries for CMOS RAM or?
  3. #23
    My XT has it. I thought it was an emergency exit!
  4. #24
    Emergency exit screwed from outside?
  5. #25
    6,922
    Quote Originally Posted by romanon View Post
    I am pretty sure that the question has been asked on this forum before. One of the suggestions was that IBM may have been allowing for a possible future use where all slots are populated (i.e. no slot blanking panels), and a cable needs to be run from inside the case to outside the case.
  6. #26
    So place here battery pack in XT-286 was great idea. At least some...
    I suppose, that for same purpose is whole on IBM 5150
  7. #27
    May 2016
    Fairfield, Ohio
    505
    I always thought it was a blank to mount an extra serial or parallel port. Later tower designs included pre-cut blanks you could punch out for a db9 or db25 connector.
  8. #28
    Mar 2006
    Massachusetts, USA
    1,900
    I use that hole in the 5150 to snake out cables.
  9. #29
    I want to know something about late XT motherboards, which was redesigned from 64-256k to 256-640k. I saw some MBs which has sticker on "64-256k" and there was "256-640k" written like here:
    Also circuit 74LS158N was added to socket U84
    It can be assumed, that IBM recycles their older motherboards to produce 256-640k boards, or it is clearly custom made?
    I have also such a motherboard, mine sticker is actually writen by hand...
  10. #30
    Adding a 74LS158N to U84 and soldering a wire to jumper pad E2 allows you to put 640k in what previously was a 64-256k board.
