Results 1 to 10 of 13
Thread: Verified: TWO revisions of the Type F Key 83 Keyboard
    Default Verified: TWO revisions of the Type F 83 Key Keyboard
    So a while back a thread was posted on a very early revision 5150A. More interesting to me was the fact that the keyboard connector on this board was metal in nature and not the usual molded plastic with the IBM logo. The early consensus was that it was a replacement after market connector.
    However, since that thread was started I noted two other instances of the same connector, all associated with very early 5150As.
    So today when I saw an IBM 83 Key Model F at the local Goodwill with the metal connector I had to pick it up for the princely sum of $5 . I got home and got one of my plastic connector keyboards and opened them up sided by side. This is what I found:
    The only external difference between the two keyboards is the connectors. Internally though it is a different story. The basic design and construction are the same given that the external frame are the same part numbers for both keyboards. However, the earlier revision board has a much less integrated circuit board. The internal part numbers are also different. The earlier boards have a lower part number. There is also a reference to a test number and much more info on who prepared and tested the keyboard.
    Current Wish List: 1. IBM 7531 Industrial Series PC 2. NEC MultiSync XL (JC-2001) Monitor 3. Copy II PC Enhanced Option Board (the one with the toggle switch on the back) 4. MicroSolutions MatchPoint AND/OR UniDOS card 5. Compaq 14" VGA CRT Monitor (the one that came with the SystemPro)
    If you have any of the above for sale please PM me. Thank you!
    Here is a close up of the circuit board and the Intel IC used:
    Early Revision
    More Common/Later Revision
    Unfortunately my KB with the metallic connector did not come with a box so I don't know if the part number was different on the box. Also mine was missing the sticker on the back panel which lists the part number so again I am not sure if there is a difference in that part number (it is 1801449 on the newer board). I'd assume there would be as there is a difference on the internal part numbers.
    Sep 2011
    Napa, CA, USA
    779
    3
    I'll have to check out my keyboards tomorrow, see if I have one of the odd PCB ones, the only odd 83 key Model F I have (and have seen in real life) is a EMR keyboard, with shielded guts, cabling, etc. The cable there reminds me of the EMR keyboard cable, as seen here.
  4. Default
    The 1983 IBM XT technical reference describes "Type 1" and "Type 2" keyboards. Looking at the date codes, I'd guess that they switched to "Type 2" in late 1981 or early 1982. The schematics show completely different circuits, and the microcontroller code would have to be different too. Are you able to dump the contents of the "Type 1" microcontroller?
    (I recently stripped down a "Type 2" keyboard for parts, which I think must have been quite an early one of its kind: its microcontroller was an 8748 (with EPROM window) rather than an 8048, the cable had the 'reset' pin connected, and the plug was black plastic but without the moulded "IBM".)
    John,
    I checked out both the First Edition and he Revised (2.02) 1983 IBM XT Tech Ref and could not see a reference to the two keyboard types. Can you tell me what page you found it on? Thanks!
  6. #7
  7. #8
    Quote Originally Posted by JohnElliott View Post
    Thanks for that. Based on the diagram the keyboards with the metal connector are "Type 1" where as the more common ones seem to be "Type 2".
  8. #9
    As per the other thread, I just bought a keyboard (supposedly in its original box) with a metal connector. The only number on the box is 1501100. No stickers on the box, no sticker on the keyboard.
  9. #10
    Quote Originally Posted by Compgeke View Post
    So this is an EMR keyboard?? Did someone just switch the name plate on the front?? will it work with a PC ? I haven't tried it with a PC.
    Attachment 14261Attachment 14262Attachment 14263
