Results 1 to 8 of 8
Thread: XWindows wonky colors with DSL?
    Default XWindows wonky colors with DSL?
    I have installed DSL on a Compaq LTE Elite 75mhz. Works pretty awesome and my Orinoco wifi card even works right out of the box. Getting X working was a bit trickier but I have gotten it to work. When X starts up the colors look great and then they fizzle out. It should be 8bit color but it looks like it turns into 16 bit colors.
    Check out this youtube video of it starting up. Why would the colors start to look great and poop out?
    That doesn't look like a change in bitdepth so much as it looks like your desktop environment is redefining the palette without adapting your wallpaper to it.
    Interesting. I tried to change the wallpaper to another image (http://www.damnsmalllinux.org/wiki/h...wallpaper.html) and now I have no background at all and have also lost the dock bar on the bottom...awesome!
    Oh, the joys of X...
    I pulled up that same image and it's still botched but a different color of botchery.
    On a positive note not only do my Orinoco wifi cards work out of the box but my Cisco Aironet 340 does as well.
    New Zealand
    4,101
    4
    Quote Originally Posted by pcm2a View Post
    That's good to here somthing is working out ok.
    I had Mandrake 6.5 on one of my 486s. It had only 512k of vram with 64megs of ram and was ok normally but as soon as I opened Gimp the screen colours would go heywire and the window the mouse pointer-gimp tools etc- was over looked ok but as soon as the mouse pointer moved away there was screen colour jiggery pockery. I was using WindowMaker as my wm at the time IIRC. Ran ok too.
    Washington U.S.
    460
    It looks like its running in 256 color mode and the X11 pallet handling is fairly poor.
    It would be nice if someone could develop a viable replacement for X designed for local use.
    Dec 2011
    NJ
    809
    13
    If you're still working on this, can you paste your xorg.conf on here?
    You may want to build X from scratch so that it's configured for a very low-end video card... now I know that isn't exactly appealing, but I have done it before without too much trouble. Make sure to configure for 486 systems if you decide to cross-compiler (recommended!).
    http://www.linuxfromscratch.org/blfs...nstalling.html
