Results 1 to 10 of 72
Thread: Trident VGA and IBM PC
    Jul 2010
    Silicon Forest, Oregon, USA
    667
    Default Trident VGA and IBM PC
    Hi,
    I am wondering if anyone has/had the original IBM PC 5150 working with Trident TVGA8900 or TVGA9000 cards? How about IBM XT? (Not clones).
    Michael and I made a weird discovery that TVGA9000i based card that I designed doesn't work in IBM PC 5150/Retro-PC, but it appears to be working in XT systems (or at least Turbo-XT clones). I tried some other Trident cards (TVGA8900D, TVGA9000A), and they also don't work in my 5150 motherboard...
    Is it possible that something on PC bus is different from XT bus that will make card not to work? If I remember correctly bus control signals (/IOR, /MEMR, /IOW, /MEMW) have termination resistors in PC, but not in XT. Also in PC 8259/PIC data bus is connected directly to the CPU, while in XT it sits on the X-bus, behind ISA. Any other ideas?
    What it is not:
    - It is not 8088/V20 compatibility issue. Trident cards will work with either one of them (on XT systems)
    - Most likely it is not a BIOS issue. Other VGA cards work with my 5150, and Retro-PC uses ERSO-like BIOS.
    Thanks,
    Sergey
    My XT works fine with a TVGA9000B.
    A while back i tried a Trident TVGA9000i card in my IBM PC 5150 and IBM XT 5160 and it didn't work in either, However it worked fine in my IBM 5170 in an 8-bit / 16-bit slot, i put it down to the bios on the card needing a 286 or better. I have also found that some cards i have work fine in my XT 5160 but don't work in my PC 5150 and a few work in both 5150/5160.
    Sep 2012
    Indiana, USA
    394
    I have Trident TVGA9000C and a TVGA9000i based cards and can't get either of them to work in a 5160 motherboard currently on the bench.
    Sep 2011
    Michigan, USA
    162
    I have several of Sergey's 8 bit ISA video cards, which work OK in a 386, 486, etc, but do not work in an original stock IBM PC, the PC-Retro running the Anonymous/Generic BIOS, or in an IBM stock XT. I have tried both versions of the Trident Video BIOS (Version D4.01E and D3.51). Just for the heck of it, I also tried booting with the Compaq Portable BIOS, just to see if it would make a difference: No dice. Trying to boot with the video card gives a characteristic error: One long beep, followed by two short beeps. As a cross check: I can boot fine in all my systems with a 16 bit VGA video card based on the ET4000AX from Tseng Labs.
    Going through my collection of VGA cards I found a single card based on the TVGA9000B using the Quadtel V3.00 lH Bios that does provide video output in a fashion on the PC... The screen is readable, but has a red background and vertical lines. I pulled the BIOS off that card and tried in the Sergey Card, but again: no dice.
    If anyone has an idea or suggestion of something to try... Thanks, Michael
    Sep 2011
    Michigan, USA
    162
    I have also tried the Sergey 8 bit ISA video card in an IBM 5150 PC with the 8088 CPU replaced by a BREAKTHRU 286 Upgrade card. (Replaces the CPU at the socket with a plug-in cable going to an ISA card with onboard 286 CPU). The VGA video card is not working, and the system seems to hang about at the point that I would expect it to be loading the video bios. No beeps.
    Jul 2009
    Central Florida
    3,704
    FWIW I have also never had any of those 2 models of Tridents working in an XT. Supposedly the TVGA8800 will work. But that was something I heard.
    *FrankG*
    Quote Originally Posted by mmruzek View Post
    What a pitty. I missed this thread. A month ago or so I assembled Sergey's VGA card and tried it in a TurboXT system that works with 9000B and 9000C Trident cards. Sergey's card did not work. I was pretty sure, I soldered it well. So I went to a friend with hot air rework station, removed the chip. Soldered second chip. (I bought two at UTsource) That chip did not work neither. I removed that chip and ordered third chip from UTSource, this time from another batch. Well I am still waiting for the chip. But today I have made a discovery. I tried 16bit 9000i card in my TurboXT and it does not work. So I pulled Commodore PC20-III (XT clone) from basement where this card worked before and .. yep it works. I am pretty sure, Sergey's card was all well, but I did not test in Commodore unfortunately .. What a mess.
    Jul 2010
    667
    Quote Originally Posted by archeocomp View Post
    Sorry about this mess... Still I am wondering what makes Trident 9000i to work in some XT clones but not in other.
    It may come down to BIOS revision.
    My emulators!
