Thread: Best tool to delete path files ?
    Default Best tool to delete path files ?
    Hello :
    I'm search for best tools to delet path files , I try some programs but always facing many problems to deal with this type of files
    any idea ?
    wata7di
    Hello u may give a try for Long Path tool , helped me so much last year to deal with path files
    The most effective and efficient is longpathtool ,it is a small,smart and quick to use software which can be easily downloaded from its site,it has optimum functionality and it can change,search,map from network,omit,copy,install and delete such long path file effectively. May be this can solve your problem.
  4. Default
    Long Path Tool4.8.3 deletes/unlocks, copies/renames path too long files/folders. Long Path Tool can simplify and probably end your problems in unlocking, managing and renaming files that appear to have a long filename. Since in some instances, you may have experienced problems accessing, managing and even renaming files that have more than 255 characters, this utility has been made to answer this particular scenario. If you have also encountered problems like error messages that tell you that the path too long, too long path, destination path too long or cannot delete file then this program is definitely for you.
    Default Long Path Tool
    Have you tried 'long path tool'?
    it's very helpful for me.
