Page 3 of 14 FirstFirst 123456713 ... LastLast
Results 21 to 30 of 131
Thread: KAYPRO and KayFreHD as a hard disk module
  1. #21
    Quote Originally Posted by lisa2 View Post
    My Kaypro 2X has a 21/84 board. All I need to do is solder a connector to J9 to use the KayFreHD?
    Attachment 16732
    Thanks,
    Rick
    Hello Rick,
    you have to populate the connector J9 and some TTLs (U28, U31, U37....)
    Frank
  2. #22
    May 2012
    Auckland, New Zealand
    90
    Quote Originally Posted by Frank S View Post
    Hello Rick,
    Frank
    Would it be easier just to use the Z80 L shaped adaptor with this machine?
    SBC6120 / PDP11 + VAX / TRS-80 / Kaypro / Northstar / Home Brew Z80 / BBC / Amstrad / Commodore
    http://www.quicktrip.co.nz/jaqblog
  3. #23
    Quote Originally Posted by jaquinn View Post
    Yes, this is a good question as I have an original Kaypro 2 (2/83) system also, I would be handy to use the same adapter for both.
    Back to the subject of my un-populated 21/84 board, is this common? In other words, do most non hard-disk equipped Kaypro's with
    "84" boards have J9 (and the associated logic) populated?
    My guess is that there is a lot of "stripped" 84 type boards like mine out there.
    Rick
  4. #24
    AFAIK, that is a "universal" board and is found in a number of different models. I may have to make the same changes to my 4/84.
    g.
    Proud owner of 80-0007
    http://www.f15sim.com - The only one of its kind.
  5. #25
    The EPROM expander boards are arrived.
    Who wants are bare PCB, please send a PM.
    The price for the bare PCB is 9$. Shipping is depending on receivers location.
    Frank
  6. #26
    May 2012
    90
    Philip Avery was generous enough to allow me to test my FreHD Kaypro adaptor with his Kaypro II and I can confirm that with two small modifications the adaptor for the 81-240-n motherboard (4/83 and some II) will also work with a 81-110-n motherboard (earlier II) that was in Philip's machine.
    I will add an new blog post with the details in the next couple of days and provide updated design files for anyone who wants to build one.
  7. #27
    I know it's been a while, but are the adapter boards for the Kaypro 10 and Universal Board equipped Kaypros available yet? If not, could I get the gerbers so I can have some made?
    tnx.
    g.
  8. #28
    Hi Geneb,
    i only let produce 3 protype boards.
    One of them is gone, two are installed in my Kaypro's.
    My layout i did in Target V13, don't know if there is a Gerber export function.
    Perhaps Jaq has some spare board over.
    Frank
  9. #29
    Rats. If it was the free version of the tool, you're locked into a single PCB house.
    Is the schematic you posted still accurate? If so, I'll craft up something.
    tnx.
    g.
  10. #30
    I've re-drawn the schematic in Eagle:
    http://www.geneb.org/frehd-kaypro-adapter.png
    If someone would be so kind as to check my work - verify what I've drawn matches the schematic that Frank posted in message #7, I'll upload the Eagle & gerber files for people to download and I'll get some ordered from Osh Park.
    Thanks for your hard work Frank!
    g.
