Results 1 to 2 of 2
Thread: Plzzzzzzzz help
    Default Plzzzzzzzz help
    I need to describe a procedure for rectifying the Hard Disk drive not being detected.
    6,526
    Amy,
    You haven't provided much info. For example, is the procedure only applicable to a serviceable computer that's just failed?
    What about this answer?
    1. Check computer's CMOS setup.
    2. Check/reseat power/data cables to drive.
    3. Check/replace hard drive.
    4. Check/replace power supply.
    5. Check/replace motherboard.
