Results 1 to 8 of 8
Thread: Hyundai Super 16TE mobo. Dead or not?
    Unhappy Hyundai Super 16TE mobo. Dead or not?
    hello again. I have a problem with my Super 16TE. It won't boot. Its XT PSU smells like burning so i am not using it at all. I use a AT psu, where i cut P8 2 right wires since the Original PSU didnt use them (however one of the 2 pins exists on mobo). I tried several times to boot it up but only failures. Total hardware 99 has different jumper pinout (mine has 2 jumpers less) so i am not sure if i use right settings. Speaker won't work at all. The only thing that makes me feel mobo works is that if i plug the FDD cable wrong (no.1 to 33 etc) the drive's led will light and the motor will start. But still nothing happens. Also 8088 is starting to heat up very fast in only one spot, under AMD logo. The other is cold. Any suggestions? Hope you can understand what i wrote
    6,139
    Quote Originally Posted by aquasonic View Post
    Bad news. That does not indicate that the motherboard works.
    6,139
    Any suggestions?
    It doesn't sound like you are connecting the PSU correctly.
    If the motherboard was good, you may have just killed it.
    The 'cut wires' is worrying.
    Send a picture.
    Finaly i figured out everything after i got a replacement board from a friend of mine (how lucky is that?). The older user tried to OverClock the motherboard or modify it in some way since there are some soldierd cables and a crystal who don't exist in my new one! The cutting i did at my PSU didn't harm it at all since i am using it with the new motherboard and it works as a charm
    I only need to find a XT keyboard My first IBM clone is workiiiiiing!
    Apr 2006
    Pinon Hills, California, USA
    311
    Thank goodness.
    You might be able to find an XT/AT keyboard, one that has a switch for or automatically switches between modes.
    is there anyway i can modify my AT keyboard to work?
    6,139
    Not economically
    Here is converter:
    http://www.clickykeyboards.com/index...id/0/id/176955
    It would be hard to make one, but if you are qualified 'd be easy .
    15 $... lol
