Results 1 to 4 of 4
Thread: Turbo Pascal for Intel 8080 ?
    Default Turbo Pascal for Intel 8080 ?
    Is there a turbo pascal (cpm80) for the 8080 ? - not Z80
    Where can I find a copy?
    thanks ..lak
    Did you try the version at http://www.retroarchive.org/cpm/lang/lang.htm?
    The manual should be there soon as PDF. Otherwise try
    http://oldcomputers.dyndns.org/publi...comp/tp30/doc/
    Fred Jan
    Turbo Pascal 1.0 and 3.0 from retroarchive as mentioned above run on an the 8085 side of a Zenith Z-100 and a CompuPro 8/16 with no problems.
    Thomas Martin
    May 2003
    Back of Burke (Guday!), Australia
    2,905
    Default Re: Turbo Pascal for Intel 8080 ?
    "Lak" wrote in message:
    > 8080 ? - not Z80
    Sorry, AFAIK they only made them for the Z80.
    However, I'm not sure if someone made a patch
    for it to work with the 8080's, unfortunately that was
    one of my hair brained schemes from quite some
    time ago :-(
    CP/M User.
