Results 1 to 10 of 17
Thread: Kaypro II Keyboard (Coiled Cable) Wiring information
    Mar 2013
    Chaffee, MO
    1,441
    Default Kaypro II Keyboard (Coiled Cable) Wiring information
    I wanted to make a spare Kaypro II Keyboard cable, since my original coiled Cable was beginning to deteriorate.
    The following information is located in the Kaypro II Manual.
    J3 Pin 4 (Black) - Keyboard Serial Data Out (to Keyboard) TTL Levels
    J3 Pin 3 (Red) - Ground
    J3 Pin 2 (Yellow) - Keyboard Serial Data In (from Keyboard) TTL Levels
    J3 Pin 1 (Green) - +5 VDC
    I had purchased some RJ-22 Modular Plugs and a set of Crimpers from Fry's Electronics. I used my OHM
    Meter to OHM out the Original Keyboard Cable as follows:
    I oriented the RJ-22 Modular Plug with Brass Contacts UP, and Pin #1 is on the Left of RJ-22 Modular Plug.
    J3 Pin 4 (Black) - Keyboard Serial Data Out (to Keyboard) TTL Levels...............BLACK WIRE.....
    J3 Pin 3 (Red) - Ground............................................ ....................................RED WIRE.........
    J3 Pin 2 (Yellow) - Keyboard Serial Data In (from Keyboard) TTL Levels..............YELLOW WIRE..
    J3 Pin 1 (Green) - +5 VDC............................................... ...............................GREEN WIRE....
    .................................................. .........................................Keyboard Serial Data in (from Motherboard) TTL Levels - KB Pin 1 (Black)
    .................................................. .........................................Ground... .................................................. ................. - KB Pin 2 (Red)
    .................................................. .........................................Keyboard Serial Data Out (to Motherboard) TTL Levels - KB Pin 3 (Yellow)
    .................................................. .........................................+5 VDC............................................... ...................... - KB Pin 4 (Green)
    Case Plug Pin 1 goes to Keyboard Plug Pin 4
    Case Plug Pin 2 goes to Keyboard Plug Pin 3
    Case Plug Pin 3 goes to Keyboard Plug Pin 2
    Case Plug Pin 4 goes to Keyboard Plug Pin 1
    Larry
    I had several Kaypros (back in the day).
    A telephone handset extension cable (the one between the phone and the handset) can be used for the Kaypro keyboard.
    If you can still fine one.
    I had a couple that were twelve feet long. Worked fine.
    Quote Originally Posted by cavelamb View Post
    I just tried a telephone handset cord with my Kaypro 2 and none of the keyboard keys worked.
    Larry
    Larry what CABLE did you use? I understand that "regular" coiled phone cable won't work - something about the resistance being wrong. Or maybe the light weight of modern phone cable is not enough to carry the 5 volts? Or both?
    Mar 2013
    Chaffee, MO
    1,441
    I'll have to go to the basement and do a bit of digging. I'm still using my original cable, but it
    needs replaced. I made some spares and have them on the table with the Kaypro. I won't
    know until I find them. I'll look tonight as I'm headed that way trying to finish another project.
    Larry
    Jan 2012
    Connecticut, USA
    2,707
    Quote Originally Posted by SMichelsen View Post
    Yes thats basically it. If you can find a coiled cable from the 70's or early 80s that actually uses copper braid wire.. you will be fine.. If you use a modern phone line which uses... garbage.. forget it.. the resistance is way too high.
    Today I tried to use the keyboard cable from a Mac Plus - didn't work.
    Mar 2013
    Chaffee, MO
    1,441
    Well, I've moved and around my Kaypro II, I don't see any extra keyboard cables that
    were made from flat or round gray cable. I don't remember what I did with the cables
    I crimped ends on or where I got the cable. I know we had some flat cable at work,
    but I don't find any of it around my Kaypro. So, I'm still digging through a few boxes.
    Larry
    As I recall, the MAC used a different cable wiring and so will not work on the Kaypro.
    - Doug
    Mar 2013
    Chaffee, MO
    1,441
    I did look in my All Electronics Book and found this information.
    https://www.allelectronics.com/
    CAT # CB-47F
    https://www.allelectronics.com/item/...ne-wire/1.html
    7' 4-CONDUCTOR SILVER SATIN PHONE WIRE - AWG28 Stranded 2 for $1.00
    Cat # 4CF
    https://www.allelectronics.com/item/...le-wire/1.html
    4 COND FLAT TELE WIRE - AWG28 Stranded 50' for $5.00
    Cat # CMP-4
    https://www.allelectronics.com/item/...g-rj-11/1.html
    4 PIN CRIMP-ON MODULAR PLUG RJ-11 10 for $2.50
    I may have built mine with something like this. I'm still looking.
    Larry
