Thread: Altos 586 with Xenix 2.5a running :)
    Default Altos 586 with Xenix 2.5a running :)
    Just thought it was cool this machine still works and so I thought I'd share it
    Its an Altos 586 running Xenix 2.5a
    I had some trouble getting on the system as it was set to tvi920 and well, I dont have that lying around but finally got there and changed tty2 to VT100 for later
    My collection of brochures : http://classic.technology
    Aug 2009
    Oslo, Norway
    1,221
    3
    Nice!
    Well done there.
    Torfinn
    So now to start using the multi-user functionality of this machine.
    I have set tty2 to vt100, 9600 baud but I dont seem to be able to get any signs of live from tty2 ?
    I am using the same cable as tty1/console so it should work, my breakout box also shows the same lights so well hmm, lost :S
    Anyone any hints ? Do I need to enable tty2 somewhere perhaps ?
    Logged in as root:
    enable /dev/tty2
    Something of that sort in the old Xenix days.
    That command works but it was already enabled.
    But I found it
    The command you need to enter is "multiuser"
    Didnt thought of that myself but found this : http://chiclassiccomp.org/docs/conte...x_QuickRef.pdf
    Now I just need some more nullmodem cables/converters and then I connect it to my Moxa box and after that I need to think how I can savely make it accessable to some people on the internet :P
