Results 1 to 4 of 4
Thread: Zobex HDCI
    Question Zobex HDCI
    Hello everyone,
    I have this Zobex HDCI card... Does anyone have more information about this board?
    The name suggests that it is a hard disk interface card.
    I was expecting something like a SASI interface. But this card has a
    powerful +5V output at the 50 pin connector to power an external board.
    Pins 43 to 50 are all +5V. These lines are GND and data at a standard SASI interface.
    So it is definitely not a standard sasi bus but maybe modified for use with a special cable?
    It seems the card does only some addressing and buffering.
    Does anyone have more info about this board? Thanks in advance!
    Regards, Roland
    Wanted: case for Altair 8800 in good or bad shape or even a replica.
    As time goes by, more and more info shows up on the web...
    The Zobex HDCI is a WD1000 S100 controller!
    Does anyone have documentation and software for this board?
    Regards, Roland
    Dec 2011
    Minnesota, USA
    211
    I came across some software on bitsavers for the Zobex board
    http://bitsavers.informatik.uni-stut...odos/programs/
    driver supports an 18 Mbyte hard disk controlled by the Western Digital WD1001 Winchester Disk Controller coupled to the S100 bus via the Zobex HDCI interface.
    Great! Thanks a lot! This probably makes the difference between a useless board to a working S100 hard disk controller.
    I have a WD1002 controller. The software describes the WD1001. I'm curious if there are many differences.
    If I remember correct the main difference is powering trough the bus or not... I hope there is any info about
    the dip switches to be found in the software...
    Anyway: Thanks! This helps a lot.
