Results 1 to 10 of 11
Thread: WD8013EBT & XENIX ... what jumper settings are recommended ?
    Default WD8013EBT & XENIX ... what jumper settings are recommended ?
    Trying to use a WD8013EBT and XENIX 2.3.4 with TCPIP package, but I was unsure what h/w configuration would be suitable for the network card itself.
    This card has really a lot of jumper, and for me not all of them have a self explanatory imprinted labeling.
    There is a jumper with a label "W0B" ( see also http://stason.org/TULARC/pc/network-...t-WD8013E.html ), it seems to be the databus 8/16 selection.
    What databus setting should I use for XENIX ? The card itself has a 16 bit ISA bus and is plugged also in a 16 bit ISA bus. So it's 16 bit for sure (but XENIX doc does only mention a WD8003 with 8 bit bus) ?
    I/O base was set to 380h, IRQ to 10. You can enter these two settings also during the TCPIP package setup process.
    And I didn't insert a boot ROM, so no other settings should be important I guess.
    Any suggestions about configuring this card (with XENIX) are welcome
    I don't have that exact card, but I do have some SMC 8013WC's made in 1993, and a WD8003WC made in 1991.
    This card family has an I/O base address, IRQ, and shared memory address that must be configured, and an optional boot ROM. For example, I/O address 0x280, IRQ 10, shared memory at 0xd8000, and no boot ROM,might be appropriate for various UNIX systems as long as those choices don't conflict with anything else in the system. Many of the later cards in the family, including the ones I have, include a configuration EEPROM to allow soft configuration by a DOS program, but the picture of the WD8013EBT I found online does not have a "SOFT" setting, so it probably needs to be configured completely by jumpers.
    Try to read the docs for your software and see what it expects, and also check the other hardware in your machine to ensure no conflicts. I hope this helps.
    Hmmm, it is now unclear to me if the WD8013EBT has internal RAM for packet buffers because I don't see it in the jumper list. Maybe the RAM and ROM are always contiguous, i.e. set ROM base and disable ROM for RAM base. Anyway, here is more complete configuration info.
    EDIT: further reading says that the 8013EBT definitely has shared RAM (up to 64 KiB). Perhaps software configures where it goes at run time...
    Quote Originally Posted by Uniballer View Post
    You're right. There is "EZSETUP" (for DOS) which is made for configuring the RAM start address.
    Unfortunately both of the versions of EZSETUP (1.02 and 1.22) shows me a message "no adapter found" with my plugged WD8013EBT.
    I've read there can be an address range already taken by another card (and that can be a reason for it, but there is no further card inserted, which uses a larger address range (for ROM or RAM).
    So I tried another card I own, a WD8003E - with this card, I was able to start the DIAGNOSE software, but it shows me a "RAM error".
    I am now totally confused, does this mean both cards are defect ?
    Or is my 486 PC "incompatible" ? But then why ? There is a Multi-I/O card inserted, and a Trident 8900 VGA. Nothing else.
    And I am not able to find another reliable source for the DIAGNOSE and EZSETUP software for the above mentioned 80xx cards.
    Quote Originally Posted by z80eu View Post
    The WD8013EBT is pre-PNP, so I think it has to be set to I/O address 0x280 for EZSETUP to find it.
    I would try reseating the card, and make sure that EZSETUP says the RAM is in a reasonable place before I believed it.
    Because I couldn't get positive results, I already set both cards to I/O address 0x280. It doesn't change anything.
    And I plugged / reseated the cards more than twice (also because of changing the jumpers - I can't change them if the card is plugged in, not enough space for my hand and I can't see it properly).
    I read some comments about the bad compatibility of the WD cards with VGA cards, but no details.
    Did you try a different slot (who knows)?
    Possibly useful SCO link.
    Not sure how applicable this is to your case, but here is the most lucid and detailed explanation of a WD8013 conflict (relates to BSD, but who cares: the hardware is the same).
    3.1.5	After installing the patchkit and recompiling the kernel with the
    	option "WD8013", I am no longer able to reboot the machine.  A
    	cold boot (power on) runs fine, but after a reboot no boot drive
    	is found by the BIOS.  Besides having a 16-bit WD/SMC Ethernet
    	card installed the machines try to boot using either a Adaptec
    	1742 or 1542 SCSI board to boot from.
    	This answer was provided by Hellmuth Michaelis (hm@hcshh.hcs.de)
    	and by Rodney Grimes (rgrimes@acacia).
    	Remove "option WD8013" from the config files and recompile and
    	reinstall the kernel.
    	The reason that option WD8013 often causes this reboot problem is
    	this:
    	There is a requirement that all memory within a 128k bank in the
    	0xA0000 to 0xFFFFF region be either 16-bit or 8-bit.  On a cold
    	boot, the WD8013 boards are reset to 8-bit mode, the POST
    	(Power On Self Test) passes without error.  NetBSD comes up, the
    	if_we.c driver places the WD8013 in 16-bit mode.  Now on a soft boot
    	when the BIOS runs some quick POST tests it finds a problem in the
    	0xA000 to 0xF000 region.  You probably get a "beep-beep" when this
    	happens.  It means you have a memory size conflict.
    	The machine has been mis-configured.
    	This is a little known fact about 16-bit vs 8-bit option cards.
    	It has caused more than one person to go crazy tracking down
    	what they swear is a bug in the program.  It is not, it is a
    	flaw in the design of the ISA bus.  The signal MEMCS16- must be
    	returned the same for every 128k block of memory:
     		A0000-BFFFF	Must all be either 8-bit or 16-bit.
     		B0000-CFFFF	Must all be either 8-bit or 16-bit.
     		D0000-FFFFF	Must all be either 8-bit or 16-bit.
    	In your particular configuration (WD8013 @ cc000) I suspect that
    	you have another board in the B0000-CFFFFF region that is 8-bit,
    	i.e.  your Adaptec has an 8-bit BIOS on it!
    	Try moving the board to the 0xD0000 region and see if it works
    	there, you may still have a problem as many modern system BIOSes
    	are now 8-bit.  If your system BIOS is 8-bit, try shadowing the
    	system BIOS region at 0xF0000 to 0xFFFFF, this effectively turns
    	it into a 16-bit BIOS.
    	Do not attempt to shadow the WD8013, it will cause you many
    	headaches.  In fact, it sometimes helps to turn on BIOS shadowing.
    	Some BIOSes allow to copy ROM contents to unused RAM pages for
    	selected 16KB-regions. While it is generally a good idea to turn
    	BIOS shadowing off, I have also observed that sometimes it helps to
    	turn shadowing of true ROM regions on.
    [code]
    option "WD8013", I am no longer able to reboot the machine. ...
    Forget XENIX in this case, I tried to test and configure them with DOS (which should be less complicated).
    Meanwhile I read this
    "Beware the Trident and Oak chipsets. Many clone vendors bundle these with
    their systems because they're cheap, but they break the Roell server and
    some other X implementations. Also, they appear to argue with the WD8003EP
    net card, and no re-arrangement of the jumpers seems to fix it. Xfree86
    supports the Trident, but the developers say it's slow, and should be
    avoided. The Oak is not supported."
    Source: http://www.menet.umn.edu/~bob/FAQ/faq.pc-clone
    Could this be the reason - VGA cards with Trident Chipset are not compatible with WD80x3 cards ?
    It's very possible. It's also possible that it is more nuanced (e.g. only with certain motherboard chipsets, etc.). Might be tough to figure out unless you have a ton of hardware to try with it.
    I started to think about throwing these WD80x3 cards out of the (opened) window. Why ?
    I can't get the cards working even in an IBM PC/XT. I had a second WD8003E, and I thought because there is no UMB present in a XT, I will not have any hassle with the RAM option of the WD cards.
    After setting the card at default values (I/O 280, IRQ 3, NO ROM) and after disabling COM2 of my Multi I/O card, I was able to start DIAGNOSE with a positive result.
    I never got EZSETUP running, and I tried three versions (1.02, 1.06, 1.22) of the setup program. Version 1.02 and 1.22 says, I have no board plugged in. Version 1.06 hangs and I had to reboot the PC itself.
    May be there is an other setup program working (at the time before SMC buyed WD's network division, there was a software published which is NOT named EZSETUP), but I don't have it.
    And because I own also a 3COM 3C503, I will continue to install the TCPIP package of XENIX with it. Hopefully THIS will work.
