Results 1 to 10 of 20
Thread: PT Helios II cosmetic restoration is coming along....
    Dec 2011
    East Coast USA
    805
    Default PT Helios II cosmetic restoration is coming along....
    Well I finished the chassis repaint and repair. I actually had the whole thing done, but I wasn't happy with the front panel, it was in bad shape before the restore with gouges and scratches some of which even spot repaired wasn't looking good in primer, so I chemically stripped it down to the bare aluminum and special epoxy made for aluminum repair skim coated all the areas of concern, shaped and then resprayed it back in original white primer. We are expecting some rain on the east coast so I may not be able to do a final sand on the primer and spray into black with splatter coat till next week.
    I also replaced the broken connectors on the controller cards. I found an exact match back in May at Excess Solutions in Milpitas, that place is amazing. The match is perfect that I only changed the one on each card.
    Anyway... here are some pics in progress, and also a pic of the resprayed Sol-20. Figured since I had the gun out anyway and I bought a nice new on the air regulator for my HVLP sprayer to make doing the splatter coat easier, when I did the Apple II last time I wasted a lot of paint and cardboard getting the pattern right each time I did a layer of splatter....
    after the paint hardens up a bit, I'll wax everything to protect it. I decided not to use two part paint because of cleanup...
    Cheers,
    Corey
    Nov 2012
    1,151
    Great work so far! I'd like to learn more about the "splatter" coat. Is that a special nozzle on the spray gun? Special paint? Just a technique? I haven't even considered painting anything because of that splatter finish. I do have to paint a NeXT Cube but it doesn't have a splatter coat. I have a Commodore 4040 drive who's paint is coming off as I clean it so that might be a good candidate.
    Dec 2011
    East Coast USA
    805
    Splatter coat has to do with constant low pressure. You turn down the air to the gun till it splatters on top of the painted surface. You do have to make sure you are thinned just right and use a good quality paint. I test the pattern on cardboard, lots and lots of cardboard and adjusting till the pattern matches the original. I take pictures of the original or have a sample near by for comparison.
    Each MFR has a different pattern.
    PT for example on the SOL-20 is a tight small pattern done in one direction then another while the piece is on the side. The Helios is a larger splatter pattern done in two steps one large and one small. The small and large merge to make a weird kind of spatter.
    Apple the splatter coat depends on the vintage. The earlier the II, the bigger the spatter size, but still done in two phase like the Helios.
    IBM PCs are the easiest. It seems they are very similar to a car trunk. I have had some success using trunk splatter, waiting a week to cure and overcoating...
    Cheers,
    Corey
    Wow -- impressive work! My cosmetic "restoration" tools consist of compressed air and a damp rag
    Mike
    Is that the original Sol-20 paper badge?
    retro computing at: www.neoncluster.com ....is dead
    Dec 2011
    East Coast USA
    805
    Quote Originally Posted by Nama View Post
    I have the original one, but this is a modified version of the one from your website. The size didn't match the original so I had to tweak it. Then I had it printed up on a die sublimation printer on magazine paper like the original. I guess I could have used an industrial inkjet, but this is indistinguishable from the original except it isn't faded.
    Cheers,
    Corey
    Actually I had no idea if it was original or not. It just looked really clean.
    After drawing the artwork, I never actually printed it....glad it works...looks great with your new paint job
    Phil
    Nov 2012
    1,151
    Quote Originally Posted by Corey986 View Post
    Corey, can you provide that file somewhere? I might need a copy and it's good to get it while it's readily available. I have another Sol-20 with a different name badge coming (I hope). Not sure if I want to change it but it's an option I'd like.
    Oddly enough, one of the manuals that's coming with that acquisition is an original PTDOS manual. There's no Helios II there though. It's not acquired from the original owner so I'm not sure why it's there. Unfortunately, the systems will come with no diskettes. I'll save the details of this acquisition for another thread IF it arrives. Apparently, UPS lost it yesterday. The package is marked "Delivered"... but not to me
    Dec 2011
    East Coast USA
    805
    It's not surprising that there is a PTDOS manual and no drive. By now every Helios II system either has had it's drives replaced with non-Persci or they have been completely rebuilt or thrown away. Also if the drives are shipped wrong or dropped they are destroyed as they have a glass voice coil setup and an incandescent lamp that should have failed by now. They are also very very sensitive to alignment.
    There is only one person I'm aware of who knows how to replace or repack every bearing and has had a limited amount replacement parts including gears recreated, the number of working units I know of can be counted on a little more than 1 hand. He completely rebuilt my drive set.
    As for the Logo strip, I'll send it to Nama later and he can host it since they are based on his work. BTW: the earlier units had the P swirl and the later units had just processor technology.
    Cheers,
    Corey
    Thanks Corey,
    I have updated my Sol-20 logo file with the feedback from Corey. Seems my original was a few millimetres too short and made for a bad fit.
    The revised file can be found by following the FTP link on this page:
    http://www.neoncluster.com/projects-...faceplate.html
