Results 1 to 7 of 7
Thread: uIEC and .D64
    Apr 2009
    Morro Bay, CA
    568
    Default uIEC and .D64
    I finally have gotten around to working a little with a uIEC sd card reader. It was a little confusing at first but after learning a few simple commands - I really like it. I may get a SDIDEC for my 128 if it will be recognized while in CP/M mode.
    My question is: What is the best way to extract .D64 (and all the other formats) that are on the card? I can do them on my MSDOS machine and then transfer them but life would be easier with a program that would extract them using a 64 or 128.
    Aug 2014
    Beauharnois, Quebec, Canada
    23
    The most easy solution that I know is to use a XA1541 cable if you can find one. It let you plug a 1541 drive to the parallel port of your PC.
    http://sta.c64.org/xa1541.html
    Feb 2009
    Chattanooga, TN - USA
    911
    You can use the .d64 directly.
    Just cd into them just like a directory.
    Also you can use one of the browsers for the commodore also to browse your collection easier.
    Here is a wiki page for you.
    http://www.c64-wiki.com/index.php/sd2iec_(firmware)
    The google discussion group for questions and lots of help is here.
    https://groups.google.com/forum/#!forum/uiec-users
    Later,
    dabone
    Apr 2009
    Morro Bay, CA
    568
    so I guess I'm missing something. If I am not using a browser:
    open 1,10,15,"cd/file.d64/":close 1
    (assuming I'm i am in the correct directory)
    will give me the files in the .d64? It doesn't work for me.
    keep at it, you're close (dv = DRIVE NUMBER)...in c64 mode
    How to change into a DIR
    OPEN15,dv,15:PRINT#15,"CD/directoryname":CLOSE15
    How to mount a disk image
    OPEN15,dv,15:PRINT#15,"CD:imagename.D64":CLOSE15
    so, just copy the DIRs or .D64 files to your SD card and then run these commands.
    If you've done it right you can type LOAD"$",dv
    ...to see the files in the D64. Usually run using LOAD"*",dv,1
    Note - I run a program to change my uIEC to be drive 8 from drive 10 first, then load the D64 because a lot of programs assume it's in drive 8.
    Bill
    @ BillDeg:
    Web: vintagecomputer.net
    Twitter: @billdeg
    Youtube: @billdeg
    Unauthorized Bio
    Quote Originally Posted by phogren View Post
    ...life would be easier with a program that would extract them using a 64 or 128.
    I use Errol Smith's D64it (for the C64) and D128it (for the C128 ). it seems to be picky in that it needs a 1541 or 1541-II -- not a 1571 -- to dearchive to a 5 1/4" disk. (Well, not the 1571 in my C128DCR...)
    Truly,
    Robert Bernardo
    Fresno Commodore User Group
    http://www.dickestel.com/fcug.htm
    P.S. There are D64it's for the VIC-20 and the Plus/4, too.
    Ah, I almost forgot about CBM-Command for the C64, C128, VIC-20, Plus/4, and PET/CBM line of computers.
    That would work, too,
    Robert Bernardo
