I posted earlier about a KIM I picked up, wondering about the rev history. It's a rev D sold I believe as an OEM by Rockwell. Anyway, I pretty much have that issue solved, but now I find it does not work. The seller showed pics that it worked, but when I got it, it was dead. Well actually not dead, there is a short someplace. When I apply power (Application connector pin A +5v and pin 1 to ground) I immediately get a short and have to pull to avoid damage. I can't leave plugged in. It's as if I connected the +5 and ground wires together, same effect. I have disconnected the first resistor in the chain and replaced the first 1u50v cap, but it's going to be hit or miss. There are no socketed chips on the board, I can't remove the 6502 or RAM easily. The 5V I am feeding is regulated 5V at 1.5A
Pin A is the lower pin of the front of the application connector, and pin 1 is the top pin just above pin A, correct? Seems like it to me, but just to be sure....
I also have a non-working KIM that does not short out using the same power supply, the problem with the other one is physical board damage, but electrically it's more or less OK, no major short like this new one.
My question - Any guesses as to what might be a smart way to test? I will have to try looking for shorts by probing with the power off and looking for continuity when there is not supposed to be any, but ug...Any ideas are welcome. I can also compare and contrast the two systems with the power off to look for differences.
Thanks in advance.
Bill
