Results 1 to 4 of 4
Thread: stage 1 boot failure error loading hd(40)/boot
    Default stage 1 boot failure error loading hd(40)/boot
    System was working fine one of the tech run boot -r thinking it will reconfigure the system like on a sun machine to detect new scsi card he was installing
    now system stuck at "stage 1 boot failure error loading hd(40)/boot"
    I manage to get my hand on boot disk for the OS
    tried #hd(40)unix As per documentation
    Return unix not found
    fd(60)unix.Z root=hd(42) as per forums search from net
    it didn't help either
    fd(60) unix root=hd(42)
    loads the kernal but system go into panic
    Any info how to get boot repaired will be helpful
    Xenix 2.3.4
    Thanks in advance
    30,680
    Platform? Vendor/Version of Unix?
    There's not enough information to say much yet.
    intel SCO Xenix 2.3.4
    Quote Originally Posted by ghouston View Post
    And you tried to run Xenix 2.3.4 with SCSI ??
