Results 1 to 4 of 4
Thread: TMS 1000 vintage 4-bit
    Default TMS 1000 vintage 4-bit
    Hi
    Who has dumped the ram from a TMS 1000 series using the 'test mode' ?
    Thanks
    Charles Harris
    Unfortunately, I haven't done much with a TMS 1000 at all--other than read the manual.
    33,669
    Given the fact that the TMS1000 is ancient PMOS (logic level issues) and doesn't contain that many instructions in its program ROM, it seems to be easier to simply reverse-engineer the functionality of the thing.
    I've got a couple rattling around in my hellbox, but I've never been interested in reading out the contents for what appears to be nothing more (in their cases) a relatively simple programmable timer.
  4. Default
    Do you mean "dumped the ROM"? Is that even possible? I don't see a procedure in the 1976 TMS 1000 Series Data Manual.
