Results 1 to 10 of 10
Thread: Atari 400: Stock psu is 3A... is 1A psu ok?
    Feb 2014
    east of Newark, Oh i;m luvit
    487
    4
    Default Atari 400: Stock psu is 3A... is 1A psu ok?
    I got an Atari 400 without a power brick.
    I'll pay an arm and a leg after shipping, but I found a 1A brick..
    I know stock is 3A and I've read another guy using 2.5A..
    If I recall from previous experiences, an under powered brick (amperage) will damage the device it's trying to power..
    Atari shipped the 400 with several different power supplies over its production run, the smallest being 9 VAC @ 1.7 amps (15.3 VA).
    A 1-amp supply will probably work fine. Just feel it every once in a while to make sure it's not running too hot.
    From the Atari 8-bit FAQ:
    N O R T H  A M E R I C A   INPUT = 115-120 V AC, 50/60Hz
    AC supplies (external transformers)
      9 V AC  5.4 VA  (600 mA)  Atari#CO62195/CO17539
        1030
      9 V AC  4.5 VA  (500 mA)  Atari#CO61516
        1010
      9 V AC  15.3 VA  (1.7 A)  Atari#CO14319
        400,800,822,850,1010,1200XL
      9 V AC  18 VA  (2.0 A)  Atari#CA014748/CA016804
        400,800,822,850,1010,1200XL,810
      9 V AC  31 VA  (3.4 A)  Atari#CO17945
        400,800,822,850,1010,1200XL,810,1020,1050,XF551
      9 V AC  50 VA  (5.6 A)  Atari#CA017964
    Feb 2014
    487
    4
    Sep 2012
    Indiana, USA
    489
    Hi Luvit. Listen, do be careful with it as it can indeed stress the computer if it can't draw enough power. Look for overheating with the computer as well as the power brick, or if the 400 has trouble initializing. I see a number of suitable Atari bricks on eBay for less than $20 shipped. I would be very tempted to snag one of them since they are easier to find than a 400.
    Feb 2014
    487
    4
    Yeah.. I'm nervous about it.
    I'll wait until I come across an appropriate AC adapter.
    I don't have a thing for 400, so I'm not in a rush, yet.. and I'll save $20 if my luck is good. (:
    I don't want to spend$20 and find the system is dead.. that would be Murphy's law.
    Jul 2003
    Västerås, Sweden
    6,277
    Are you raiding your local thrift and goodwill stores regularly? I've grabbed quite a few working power adapters from those, of course not original brand but 9V is 9V no matter the manufacturer. For that matter, I've read the 1.7A one was considered just barely adequate, at least for the 800 model, so it probably is wise to look for something beefier.
    Anders Carlsson
    Aug 2013
    Keansburg, New Jersey, United States
    911
    A 1A supply might power the unit fine, but things like the tape player and other peripherals draw power from the computer. You might not have enough power to add things to the computer with a smaller supply. Best to get the right one.
    -----[ Al ]-----
    3 - TRS-80 Model I, TRS-80 Model 4D, LNW-80 Model I, Coco, 3 - Coco 2, Coco 3, 2 - Tano Dragon 64, C64, C64c, C128, 2 - Atari 800XL,
    Atari 520-ST, Atari Mega-2 ST, Amiga 1000, TS-1000, TS-2068, ZX-Spectrum, IBM 5150, 2 - Apple ][gs, Laser 128, and a butt load of Macs and Intel PCs.
    Mar 2006
    Massachusetts, USA
    1,876
    Atari 8-bit disk drives require their own power adapter.
    Aug 2013
    911
    Did I mention a disk drive? I mentioned the tape drive.
    -----[ Al ]-----
    Feb 2014
    487
    4
    Quote Originally Posted by carlsson View Post
    yessir.. i pass 3 everyday.. always walking out with the weird doodads. I usually pickup any AC adapter that reaches 1A with a standard voltage.. however that's the beefiest they ever seem to have..
    like i said.. if I can stumble upon one for cheap, i'll hang-in there. -- thanks for the info on 1.7A (:
