Thread: LSMI - Laser Magnetic Storage International
    Talking LSMI - Laser Magnetic Storage International
    Laser Magnetic Storage International (LMSI) was a subsidiary of Philips that designed and manufactured optical and magnetic media. It began as a joint venture between Philips and Control Data Corporation.
    Products
    CM-100: external CD-ROM.
    CM-121: external optical storage.
    CM-201: internal 5.25" SCSI CD-ROM drive.
    CM-205: internal 5.25" CD-ROM drive (1X speed) with proprietary LMSI interface.
    CM-206: internal 5.25" CD-ROM drive (2X speed) with proprietary LMSI interface.
    CM-212: internal SCSI 5.25" CD-ROM drive.
    CM 221: external SCSI CD-ROM drive.
    CM-225: external CD-ROM drive with proprietary LMSI interface.
    CM-231: external SCSI CD-ROM drive.
    CM-250: internal 5.25 CD-ROM drive (1X speed).
    CM-50: external CD-DROM drive.
    LD-510: internal SCSI CD-ROM drive.
    The proprietary 16PIN LMSI CD-ROM interface was relatively short lived and existed on LMSI interface cards and a few ISA sound cards:
    Sound Blaster Pro 2 CT1620
    Sound Blaster 16 ASP CSP CT1780
    Media Vision Jazz 16 LMSI
    Pro Audio Spectrum LMSI
    Magnetic products were geared towards corporate mini computer environments (like the IBM AS/400).
    LD-4100: cartridge optical storage.
    LF-4500: cartridge optical storage.
    Sold under the Philips brand:
    CM-207: 5.25" internal IDE ATAPI CD-ROM[15]
    CM-208: 5.25" internal IDE ATAPI CD-ROM
    CM-218: 5.25" internal IDE ATAPI CD-ROM
    I had one of these for a couple of years. 8 bit card, 16 pin. External cd-rom that looked like a audio component with the phillips branding. Worked in a friends XT! (at least it did...guy broke everything i gave him last i knew)
    I've got the drivers for it somewhere if anyone's interested.
    Jan 2014
    Centero
    6,878
    Quote Originally Posted by salamontagne View Post
    He doesn't have a pressure washer and a YouTube channel by any chance, does he?
    Be polite and I may let you live.
    YouTube channel? Yes
    Pressure washer? Oh, no. He's quite intelligent enough to understand certain toys can cause grievous bodily injury.
    Actually, i was a bit crude with my wording. Its 1/2 a matter of circumstance (stored said XT/AT machine in a basement before he realized how badly humid it got down there) When i decided to try and revive it the traces were swollen so badly it looked like spray-on hammered-look paint. I had to sand and paint the metal of the case to prevent further rust/rot.
    Though I still can't get him to invest in a decent online ups in a house with 1/2 the wiring shot...
    ...and there's a ti-99 with the expansion chassis down there last i knew...
    Jan 2014
    Centero
    6,878
    Ouch.
    Fix the wiring, don't hide the problem. Wiring in that state really is a fire hazard. If it were me and I couldn't afford to inspect and replace and bad wiring and connections, I'd at least be inclined to install new arc-fault breakers, and derate them considerably. It would at least certainly be worthwhile to listen for arcs with an untuned AM radio receiver.
