Page 17 of 18 FirstFirst ... 7131415161718 LastLast
Results 161 to 170 of 177
Thread: Lanier Model 103 "No Problem" word processor
  1. #161
    Aug 2013
    Larose, LA, USA
    340
    Beginning to build the schematic for the CPU card in KiCad.
    Slow progress because a lot of the chips aren't in the library.
    Phil
  2. #162
    I have boot disks for the AlphaPlus 12, and 14. I have a complete Alphaplus 12. The Alphaplus 14 disks also boot the 7100. I also have boot disks for the 7200 and 7300. As well as CPU's.
  3. #163
    Aug 2013
    Larose, LA, USA
    340
    I suppose the question there is would any of those boot this machine? Then, are you able to make copies, then are you willing to make copies?
    Phil
  4. #164
    Aug 2013
    Larose, LA, USA
    340
    I decided last night to power up the Lanier. It's been off since, what, maybe some time in 2015. Took the lids off and pulled the PSU out, unhooked the machine from it, eyeing the old Sprague capacitors.
    Ran it up gently on the Variac, watching the voltages. Carried on bringing it up and everything was as stable as it ever was.. 5.04V, 12.00 being particularly stable and accurate still.
    Given that everything was present and correct, I reconnected and powered it up.
    Got the logic analyzer hooked in on what looked most likely to be the bus on the backplane. Lots of nonsense, coupled with the floppy drives going totally nuts.
    Tried to see what was going on. Removing the CPU and address decoder stops it from freaking out. It's random though. I'm thinking I might have to remove every chip and test. If I'm going to do that I'll socket them all.
    Would any of the 8080's support chips (or the 8080 itself) be damaged by being powered up without the +5V rail present? The psu had failed previously and the 5V rail was at zero.
    Phil
  5. #165
    Aug 2013
    Larose, LA, USA
    340
    Under instruction, here are the voltages present.
    -27 = -33.68
    +27 = +33.65
    +15 = +14.96
    -15 = -15.14
    +5 = +5.14
    +12 = +12.03
    -12 = -11.97
    No more than 0.006VAC ripple on any rail.
    TP1= +5.14
    TP2= +5.07
    TP3= +12.02
    TP4= +7.27
    TP5= +14.95
    TP6= +7.23
    TP7= +6.64
    TP8= -14.69
    Phil
  6. #166
    Aug 2013
    Larose, LA, USA
    340
    Powered it up with everything plugged, and it went a bit weird.
    Lost the -12V rail.
    Pulled the video card, all voltages nominal. Lightning-bolt-question-mark LED lights up. (What does that one mean? Fault?)
    Pulled the RAM off, checked it for shorts, none found. Board still makes -12 rail collapse.
    -5 appears to be created by putting a diode and 330 ohm resistor from the -12 and shorting it to 0 with a Zener. I think the Zener had gone bad. Shall pull it out tomorrow, get the numbers off it and check.
    Phil
  7. #167
    Aug 2013
    Larose, LA, USA
    340
    Yup, standard 500mA 5.1V Zener. With one leg pulled, all the RAM out it switches on and comes up (to completely blank screen of squares- expected), with a beep until the floppy drive clicks and the lights come on.
    I'll get a Zener, refit the RAM and see what it does.
    Phil
  8. #168
    Aug 2013
    Larose, LA, USA
    340
    Well, that was masking another problem.
    The -15 rail (that the -12 is derived from) is hitting crowbar when it's loaded with all the cards. Next up is to find why. Power supply in bits again.
    Phil
  9. #169
    Aug 2013
    Larose, LA, USA
    340
    Aha. Main smoothing capacitor for the -15 rail gone leaky. Soldered in a temporary replacement (15000uF 50V) on a couple flying leads and bingo. Stable voltages, with all the cards in and drives running. Tweaked to within 0.01V on all rails.
    Still does the click click clunk click thing occasionally. Periodically beeps. Not producing reliable results with each power-up.
    Derived -5V rails on video card at -4.89V and the CPU card at -4.96V.
    Phil
  10. #170
    Aug 2013
    Larose, LA, USA
    340
    Redid the caps on the CPU card tonight. One had gone all melted, where I'd not noticed.
    Went ahead and replaced them all apart from the one by the timing crystal because I'm not sure how to read the value.
    Same behavior as before. Cold, it seems to behave. I pulled the CPU and I/O cards out. Just that powered up, long, solid beep that doesn't stop and the screen is filled with repeating random nonsense.
    Plugging the CPU card and I/O cards back in make the beep go all crackly, like AM radio static interfering with it.
    With the CPU and I/O cards in, the screen always has the same pattern, though the contents of each location vary.
    Strange behavior. Definitely deteriorates the longer it's switched on.
    Phil
Tags for this Thread
