Page 3 of 9 FirstFirst 1234567 ... LastLast
Results 21 to 30 of 84
Thread: FreHD on Model II/12/16/16B/6000 - FIRST ATTEMPT
  1. #21
    Sep 2011
    982
    Gentlemen,
    The aim here is to see who can get a modern digital storage device working on these machines... I am most familiar with FreHD so that is why I look at the problem from that angle, however I have much respect for Hans01's work with the Cheapo-IDE and if that is the best angle for him to work from then I encourage him in his work. Its very possible that if Cheapo-IDE can be made to work, the solution will be a lot less expensive than a FreHD solution.
    Hans if you need anything from me to get started, let me know.
    @lowen, that's great to hear about the HDINTRQ, let me run it by Fred and Andrew.
    Cheers,
    Ian.
  2. #22
    Jan 2014
    Western North Carolina, USA
    1,113
    Gentlemen,
    The aim here is to see who can get a modern digital storage device working on these machines... I am most familiar with FreHD so that is why I look at the problem from that angle, however I have much respect for Hans01's work with the Cheapo-IDE and if that is the best angle for him to work from then I encourage him in his work. Its very possible that if Cheapo-IDE can be made to work, the solution will be a lot less expensive than a FreHD solution....
    There is an INTRQ line in the ATA standard; I would have to wonder if the semantics of that IRQ are similar enough to work. Does the Cheap-O board provide continuity of the IRQ? (I'll look myself in a bit.....)
    Bughlt: Sckmud
  3. #23
    Sep 2011
    982
    Just noticed something on the Type 2 HDC which may be important, there are heaps of jumpers on the board...
    Can anyone provide a description of what they all do and why?
    Cheers,
    Ian.
  4. #24
    Jan 2014
    1,113
    We would need the service manual with the schematic to know what all of those are. I don't recall if I ever had that manual; Kelly might.
    Bughlt: Sckmud
  5. #25
    Feb 2014
    Netherlands
    409
    Gentlemen,
    Ian.
    @Ian.
    I hope we both succeed in finding a way to connect a modern harddisk solution to a Model II series computer.
    It would give the serious user a professional solution for a professional price or a hobby collector a interchangeable
    solution with some or more restrictions.
    For the moment I need a double sided prototype board with a Model II bus connector.
    I'am afraid that this not exist, but you know so much about TRS 80, I hope you can point me in the right direction.
    Or maybe you can help me with a destroyed and useless model II board where I can cut off the edge connector and some traces.
  6. #26
    They're pretty simple. They set the RAM address and the port address. Pulls up input of U26 and U1.
    From notejump.pdf page 221 and 222
    Model II/16/16B/6000
  7. #27
    Quote Originally Posted by Hans01 View Post
    I'm afraid that this not exist, but you know so much about TRS 80,
    What about a quick layout for one of the inexpensive FAB houses like OSHPark.COM? I bet we could get NF6X to lay it out for us. I'd buy a couple to play with.
  8. #28
    Quote Originally Posted by kb2syd View Post
    A full-sized Model II/12/16/6000 card is 10" x 5.5". That would cost $91 each at OSH Park in the 2-layer standard run (must order multiples of 3 boards). It could be dropped to $55 each using their 2-layer medium run (must order multiples of 10 boards, and not web-orderable).
  9. #29
    Quote Originally Posted by NF6X View Post
    What about just fingers and 80 plated through holes? Say 10" x 1.5" just so we can prototype some stuff. Or even smaller, like just the board edge and enough to insert and remove.
    Personally, I'd be good with $91.
  10. #30
    That would drop the price quite a bit. It would then cost $25 per board (must order multiples of 3) in standard run, or $15 each (must order multiples of 10) in the medium run.
    Note well: Those are the raw board prices if you order directly from OSH Park, and you would need to order 3 or 10 boards at a time to get those prices. If I was to quit my day job and sell these boards, then multiply everything by 2.5 and add shipping. And I'll need y'all to order 8,000-10,000 boards per year so I can quit my day job.
