Results 1 to 10 of 19
Thread: What Zenith computer is this?
    Default What Zenith computer is this?
    The plate is marked ZDF-1217-DY but I can't pull up any information on it.
    4,559
    Could you take pictures of the interior? I think it is a XT clone from 1988 but my information could be wrong.
    3,347
    Can you tell us anything else about the machine such as CPU, internal slot configuration, drives, etc?
    It seems to me that the early spectrum of Zenith PC compatible clones is poorly documented.
    Here are some more pictures. It is running DOS 6.22.
    I have an identical looking model, it's a Zenith XT clone with an 8088. Sadly mine has a RAM fault so apart from the cool LEDs lighting inside, I can't do much with mine
    Apr 2011
    Central Virginia, USA
    637
    It's one of the Zenith backplane systems. The CPU and RAM are on the extra tall cards. Pull them out and look for part numbers on them.
    Feb 2012
    Northern Nevada
    686
    Zenith 158. I used to maintain them as a computer services work-study in college... as stated above, it's a backplane based XT clone. Pages 9 through 12 of this brochure: http://www.thecomputerarchive.com/ar...20desktops.pdf
    We had added 720k 3.5 drives to ours in the computer labs. We removed all the hard drives (used them for spares for the faculty's systems) and used NI5210 NICs with Novell boot roms, booting them across the network. It also made it easier to provide a consistent environment. Mainly used for Wordperfect 5.1 / Microsoft Works classes, and running NCSA telnet to access the VAX cluster... this was in 1991-1993.
    Quote Originally Posted by HoJoPo View Post
    Damn that brings back some memories for me. I used to do some work at a school that had about 25 computers in the classrooms, all with Novell boot roms and no floppy/hdd at all. It was (as you mentioned) the easiest way to have a consistent working environment that you could install new software on without walking around to every single computer. Similar time as well, from the late 80's through to about 94-95 when Windows 95 came out.
    Excellent! Thanks all. This is a keeper. I have 3 IBM XT's, but this is the first Zenith XT Clone like this I have seen.
    Do you know how to tell the differences in the Z-150 series? I can also say it's in that series but I don't know all the different models, I thought it looked like a Z-150/151 to me.
