Results 1 to 10 of 17
Thread: Cleaning vintage computer motherboards
    Default Cleaning vintage computer motherboards
    Hey,
    What is the best way to clean the motherboard of a vintage computer so that it can be restored to it's original circuit board shine? Most of my collection of computers have been air dusted inside but never fully cleaned.
    What is the best method?
    -Flushy
    6,916
    I have washed boards with dish soap and a fine brush before as outlined in the above threads. I wouldn't try the dishwasher as it may be so violent that it throws the board around.
    Remove the battery first as it does not like getting wet. Use a small amount of dish soap in warm distilled water; brush it over the board and then rinse thoroughly (and I mean thoroughly) with distilled water. Never use tap water or even rain water as the salts will stay behind and cause conductive tracks to form between the smaller pins on the IC's.
    I then blew out most of the water using an air compressor, stood the board up on its edge in the sun for about 2hrs, rotated to the other edge (etc etc) until completely (again I mean completely) dry.
    Most people go wrong with these methods because a) they don't dry the boards before powering back up, b) the IC's / board have some damage which allows water inside them and then causes more damage or c) don't rinse thoroughly with clean distilled water.
    Remember water will tend to hide under SOIC's and any large PCB componants like ISA slots, memory sockets etc. That is why I used a compressor; it's the only way to thoroughly remove water from these areas.
    As above, proceed at your own risk.
    Mar 2006
    Massachusetts, USA
    1,900
    An air compressor seems to be a somewhat expensive device. Would a can of compressed air do the job?
    I have read posts of at least one person who suggests using a space heater.
    If you have to do any more than a little cleaning the cost of canned air adds up. You don't need a "shop" air compressor, just something like this. (I have one of these and it's awesome...has much more force than canned air and it never runs out.)
    Default Fixing the Links
    I've fixed the links directly in the quote.
    Jul 2009
    Central Florida
    3,790
    I use canned air works fine. Just never vacuum a motherboard. The air being sucked in through the plastic nozzle can generate a static charge. Especially with low humidity.
    *FrankG*
    Jan 2012
    Connecticut, USA
    3,181
    I have washed plenty of boards in the dishwasher. Alot of them came out with that pcb shine again. But not all. Some of the worst with industrial grit or rust residue need hand scrubbing. But I use that method. Just dont use the heat dry at the end.
    Sep 2003
    Ohio/USA
    8,119
    Dish soap and water plus air drying work for me. My basement is pretty dry and a couple days is all they need.
    Oct 2016
    236
    You can buy a small "pancake" air compressor and a cheap hose kit from Harbor Freight for about $55, use a 20% off coupon and save more.
