Page 1 of 5 12345 LastLast
Results 1 to 10 of 50
Thread: Where Can I purchase a Tandy 1000 EX RAM Board (Plus Board) ?
    Default Where Can I purchase a Tandy 1000 EX RAM Board (Plus Board) ?
    Hi,
    I recently Purchased a Tandy 1000 EX system, which has only 256k RAM. I have DOS 2.0 running on it, and was curious where I may be able to purchase a Ram Board. I am having trouble finding one on ebay, so any help will be much appreciated. ALSO, please leave a link to the site. Thanks!
    Good luck...I doubt you'll find one not already installed in a system. Wish I could be more optimistic, but I would imagine pretty much all ever produced ended up installed in systems.
    Perhaps someone will someday make a combo RAM/XT-IDE PLUS card...yeah, I know...I'm dreaming...
    Wesley
    Mar 2011
    Atlanta, GA, USA
    1,576
    You are not dreaming. I would have one ready next week if I could find a source for the extremely tall 62 pin IDC connectors.
    Jun 2009
    Tacoma, Washington, USA. Zip code 98404
    1,472
    it might cost more, but why not craft your own? The soldering would take a little work, but it could be done.
    JOZXYQK[/B][/B]
    Mar 2011
    Atlanta, GA, USA
    1,576
    Quote Originally Posted by k2x4b524[ View Post
    I could easily craft my own - or invent my own stacking mechanism which would work just as well. However I'd like to build them for others to use.
    Feb 2012
    Northern Nevada
    698
    I have an IDC to card slot ribbon cable that works great with an XT-IDE, it was fairly common for companies to make small ISA cards that used an adapter cable in the 1000EX/HX. Would it be economical to either do that, or the make your card using a short IDC to IDC jumper cable?
    I have a clone DMA/memory card in my 1000EX that only has a single additional card connector, unlike the Tandy card which has two.
    Oct 2009
    Huntsville, AL
    1,256
    Apart from needing the DMAC for memory refresh, were there any plus cards that took advantage of DMA? If not, I would imagine a card with SRAM on it instead of DRAM would be easier to build.
    Would this work for the end to connect to the existing PLUS slot?
    http://www.king-cart.com/cgi-bin/car...g4ARoCUdjw_wcB
    or
    http://www.ebay.com/itm/181251770180?rmvSB=true
    Then route that via a PCB to two http://www.digikey.com/product-searc...=0&pageSize=25
    Just a quick start. I just used a ribbon cable to convert to 2 standard ISA slots outside the case.
    Feb 2012
    Northern Nevada
    698
    http://www.ebay.com/itm/Tandy-1000-E...item2c98a076a8
    There's one for sale on eBay, but it's kinda pricey.
    Apr 2013
    Fort Worth, TX
    155
    lol @ that price...
