Results 21 to 30 of 50
Thread: Where Can I purchase a Tandy 1000 EX RAM Board (Plus Board) ?
  1. #21
    Mar 2015
    Vancouver Island, BC, Canada
    4
    Here are a few photos of a Tandy 1000 HX with memory expansion board, homemade ISA adapter cable, and Lo-tech ISA CompactFlash adapter: http://imgur.com/a/ZJgP5
    Some quick measurements of the HX/EX memory expansion board:
    The 62-pin connector on the memory expansion card is 10 mm from the side of the PCB (photo 13), and 20 mm from the back of the PCB (photo 14). The bracket is 5 mm past the back edge of the PCB (photo 14). The PCB is 146 mm long, 105 mm wide (photo 15). I'm happy to take more measurements if helpful.
    I'm very happy with the Lo-tech ISA CompactFlash adapter, and also very impressed with the other boards I bought from Lo-tech. I would definitely buy a couple of any expansion boards made available - memory expansion, riser card, a multifunction card - I would love to see any of these!
    Is there any use for DMA in a Tandy 1000 HX / EX? Or would a memory expansion board without a DMA controller be fully functional? Would the Lo-tech 1MB RAM Board work just as well as the Tandy 1000 HX/EX memory + DMA board?
  2. #22
    Mar 2006
    Massachusetts, USA
    1,889
    For a memory board, Tandy used eight 256kx1 and four 64kx4 chips. You can cut that chip number in half by using 256kx4 chips. That will allow more room for a discrete 8237 DMA chip and the logic necessary to interface the chip to the bus. You can also loose the short connector next to the VLSI chip and just use one connector at a more standard height. Even so, I think it would take some custom logic due to the lack of space.
    A clock would be a nice thing to have, it could go on the serial board.
    The EX already has a parallel port and fitting a large connector onto a bracket will be tricky.
  3. #23
    Feb 2012
    Northern Nevada
    698
    I just discovered yesterday, browsing on Tandy's doc site, there was a second memory expansion board that came with 512k RAM installed, and a driver to use 128k as a RAMdisk (as the system would then have 768k RAM). The part number ended in 2062, instead of 1062 like the other RAM board.
    If that 128k was a high memory area useable by himem.sys, that would be very useful....
    Also, I have an aftermarket DMA/RAM board in my 1000EX, that doesn't have the CPLD the Tandy card does. I'll get some photos of it, it may be easier to clone.
  4. #24
    Mar 2011
    Atlanta, GA, USA
    1,576
    I'm not sure why you would need DMA. The only application of it is to speed up floppy transfers.
    Likewise it would be silly to add DRAMs to any reproduction when 512Kx8 SRAMs are so plentiful now.
    One could adapt something like a JR-IDE design to a PLUS form factor. Maybe drop the POST and 2nd SRAM for a DUART instead. DMA is a bit faster than memory mapped I/O. But it's a difference of 330KB/s vs at best 400KB/s. A comparison akin to which super car should Grandma drive...
  5. #25
    Mar 2015
    4
    Should DOS (or the BIOS?) detect that DMA is available, and start using it, if the memory expansion board is installed? Is there a benchmark or diagnostics I can run to see that DMA is available and compare floppy transfer speed?
    I tried a simple test of timing how long it takes to copy some files from floppy disk and didn't see any difference whether the memory expansion board is installed or not. (using the "Tandy 1000 EX Memory Expansion Board cat. no. 25-1062")
  6. #26
    Oct 2009
    Huntsville, AL
    1,256
    Quote Originally Posted by HoJoPo View Post
    I made a half hearted attempt to modify the plus memory board I had in my HX to support 768kB. In theory it should be possible as the same ASIC is used on the Tandy 1000TX. It used a different combination of DRAMs in each bank. Details are in the hardware reference manual for the 1000HX, and the associated strapping modes. I tried ripping out the 64k DRAMs and replacing them with a bank of 256k DRAMs piggybacked on the ones that were on the system and then tying back the RAS/CAS signals to the 64k dram bank's ras/cas lines and changing the strapping to match the TX. System wouldn't boot. Not sure if that's a BIOS issue or a problem with my wiring. Ended up putting it back without too much further troubleshooting.
  7. #27
    Mar 2011
    Atlanta, GA, USA
    1,576
    Quote Originally Posted by baudfiend View Post
    Then I'm not sure how any DMA function on-board the Tandy ASIC is being used. It is wired to cpu hold, hold ack, and the DMA request and ack lines for floppy. You can have all the hardware acceleration support, but if there is no software support..... ? Even if it could move data to/from other peripherals, I'm not aware of any driver with support. It's primary function is obviously to provide refresh control for the local DRAM. Maybe Tandy never got around to anything else?
  8. #28
    6,443
    Without DMA, the Tandy and PCjr disables interrupts for large chunks of time in order to transfer data to/from the drives. If you're just sitting at DOS there is not much of a speed difference, but without interrupts, attempting to write to disk while something else is happening does not go well. The classic application of this is trying to transfer files over serial/modem; on systems without DMA, there was a practical maximum speed (2400 baud or lower) before bits were dropped. The interim solution was to download to a RAM disk, then transfer to physical disk later.
  9. #29
    Oct 2009
    Huntsville, AL
    1,256
    In addition to what Trixter mentions, the PLUS memory card also supplies DMA channel lines to the two passthrough PLUS card connectors, basically making the PLUS connector look pretty much like a regular 8-bit ISA slot with a 1:1 pin mapping.
  10. #30
    Mar 2006
    Massachusetts, USA
    1,889
    At least it is not as bad as it is on the PCjr., where decoding the keyboard bit stream by the CPU required interrupts to be disabled for a long time. The Tandys have a proper serial register and should not have this conflict. However, one should not expect keys to be registered while the disk drives are active.
