Page 5 of 5 FirstFirst 12345
Results 41 to 50 of 50
Thread: Where Can I purchase a Tandy 1000 EX RAM Board (Plus Board) ?
  1. #41
    Feb 2012
    Northern Nevada
    698
    Quote Originally Posted by novasteve View Post
    Does it have to be those exact specifications? Not finding much on ebay
    Search on Jameco for 41256, they'll have them. 150ns or faster (lower numbers are faster) will work.
    http://www.jameco.com/webapp/wcs/sto...10001_41398_-1
    Buy 10 of them, and they're only $.69 each, for $6.90 total. Then you'll have a couple spares, in case you get a bad one or bend pins.
  2. #42
    Thanks so much. Bought 15 actually
  3. #43
    Jun 2014
    Montreal, Quebec, Canada
    10
    I love what this guy has done.
    https://www.youtube.com/results?sear...tandy+1000+usb
    Usb to 8bit ide floppy emulator.
    That with a built in HDD and memory expansion and you have the perfect retro Tandy. Maybe a CGA to VGA converter.
    I grew up with a Tandy 1000HX with Modem and DMA/Memory board. IT had dos 2.11 on rom and 640k.
    I have a EX with nothing added now.
  4. #44
    Quote Originally Posted by TandySYC View Post
    The USB Floppy drive is even more useful if you add an OLED display.
    I wasnt keen on replacing my real drives so I bought a drive chassis (disk drive was dead) from one of the members here and installed it into that. The nice thing about Tandy 1000's is most of them support swapping the drives around by pressing F3 at power on.
    My Retro Collection:
    Apple's: IIc, Mac SE, LCII, LC630 & Power Mac G3/233 Desktop
  5. #45
    Jun 2014
    10
    I wasnt keen on replacing my real drives so I bought a drive chassis (disk drive was dead) from one of the members here and installed it into that. The nice thing about Tandy 1000's is most of them support swapping the drives around by pressing F3 at power on.[/QUOTE]
    Very nice.
    Do you think one of these would work in a Tandy 1000 HX or EX? i know i would need a isa to plus card adapter but would that be easy enough to get working?
  6. #46
    Jun 2014
    10
    Default Awesome Build
    Quote Originally Posted by dJOS View Post
    I havce used the links to Lo-tech and tindie to come up with my ultimate build.
    Tandy 1000 HX/EX
    Part $ Link
    Tandy 1000 EX / HX PLUS-ISA Riser Card
    24.95
    https://www.tindie.com/products/Cybe...sa-riser-card/
    Lo-Tech 1MB RAM XT-ISA card
    67.99
    https://texelec.com/product/lo-tech-1mb-ram/
    NEC V20 16Mhz Drop-In Upgrade CPU For Intel 8088 IBM XT Computers
    28.59
    https://www.ebay.ca/itm/NEC-V20-16Mh...:rk:2:razz:f:0
    Lo-tech ISA XT CF Adapter rev. 3
    57.99
    https://texelec.com/product/isa-compactflash-adapter/
    Tandy 1000 Internal Gotek Adapter
    24.95
    https://www.tindie.com/products/Cybe...gotek-adapter/
    SD FW - HXC Rev F WHITE CASE
    142.72
    https://lotharek.pl/productdetail.php?id=28
    TOTAL 347.19
  7. #47
    Tandy 1000 HX/EX
    24.95
    142.72
    You dont need the "Internal Gotek adapter" to install the HXC rev F inside an EX (HX yes, but not the EX) - the power is not provided via the Floppy cable, but by a normal Molex power connector.
    You will need the following:
    3.5" to 5.25" drive bay adapter - HERE
    5.25" to 3.5" Power adapter Cable - HERE
  8. #48
    Oh and you'll need a new Amiga style floppy cable with the 3.5" floppy connector on it - HERE
    You need to make sure the cable doesnt have a twist in it as Tandy use the Shugart standard just like Amiga and Atari did.
  9. #49
    Jun 2014
    10
    here is an interesting article that may have implications if someone could use dual buffer to replace ram by using the faster pie to expand ram and other functionality. It might be possible to share the NIC, Ram, Video output and SD card through one card and one pie. food for thought.
  10. #50
    Jun 2014
    10
    Well i can't afford either of these. So here ya go guys. If you are willing to pay 2 just popped up.
    https://www.ebay.com/itm/Tandy-1000-...:rk:2:razz:f:0
    https://www.ebay.com/itm/Tandy-1000-...:rk:3:razz:f:0
    if anyone wants to be my secret santa ill take what i can get. lol
    hope one of us tandy lovers gets it.
