Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 56
Thread: Paint Color for PC/XT case ??
  1. #41
    May 2018
    Lancashire
    575
    16
    Quote Originally Posted by Timo W. View Post
    That's because you can not convert Pantone colors to RGB. RGB does not describe absolute colors, just the relative balance between red, blue, and green, which a monitor then renders "somehow" based on what the manufacturer thinks looks best. Also, RGB is an additive color model and only works for devices emitting light. If at all, you can convert Pantone to CMYK, but that won't help you much, since your monitor stays at RGB and the sRGB colorspace is very limited anyway.
    fair enough, but its still confusing.
    Current fleet
    TRS80 Model 4 - BBC B - Tatung Einstein - PCW9512 - PET 3032 - C64 - ZX81 - Spectrum 48K - Amiga A500 - VAX 3100,3300,4000VLC & 4000 Model 96 - Apple II europlus - Apple iMAC G3. Sharp MZ-80K. - DEC Micro PDP 11/73 - IBM 5160 XT - Multibus 286/10 - Alpha server - MicroVax II.
  2. #42
    May 2018
    Lancashire
    575
    16
    That makes sense I suppose, still confusing that they use different codes and the colours look different.
    Current fleet
  3. #43
    I've been watching a lot of power tool and tonka truck restoration videos recently, and I think most PCs are powder coated. I've seen a few videos where power tools were powder coated to a similar or the same sort of texture as vintage PCs and compatibles have. I think it's a part of the chemical makeup of the paint that causes it to dry that way.
    The IBM color per that forum posted as Pantone 413 U. I thing my songcheer XT case on my 486 is a similar color.
  4. #44
    Quote Originally Posted by MajorMar View Post
    Just a note that may be of interest to others. After considering the hardness issue of latex and examining the paint on some other projects I have done in the past, I decided to try out this latex paint hardener from Crown. You can get it direct or have it shipped to a Home Depot. When it comes in I will do some tests both with and without the hardener added. The final cure is 7 - 14 days, so I will update once I have some results in a few weeks.
    Attachment 62164
    Please do update us. I am interested to hear if you can get the same feel and hardness as the original paint...
    Current Wish List: 1. IBM 7531 Industrial Series PC 2. NEC MultiSync XL (JC-2001) Monitor 3. MicroSolutions MatchPoint AND/OR UniDOS card 4. Compaq 14" VGA CRT Monitor (the one that came with the SystemPro). 5. Stacker HW CoProcessor Board MCA BUS. If you have any of the above for sale please PM me. Thank you!
  5. #45
    May 2018
    Lancashire
    575
    16
    Just got a matt rattle can of cellulose 413U paint.
    Its colour is a reasonable match, it has that 'greenish' colour but its looking lighter than the original, but that might be because the original paint is so dirty.
    No pictures until I have completed, but the case will need a full rub down due to the damage and will have to lose the speckled effect or it will look daft. Haven't managed to find a way to replicate it, but as its matt, an initial test spray actually looks fine.
    Current fleet
  6. #46
    May 2018
    Lancashire
    575
    16
    All done
    Not been able to recreate the finish and the pictures don't do justice to the colour as the LED lighting is too white, but I am happy
    Not too bad to say it was badly smashed.
    Current fleet
  7. #47
    Nice job! You may want to take some picture in natural light to better illustrate the color if the LED lights are not working for you.
    How does it feel to the touch?
  8. #48
    May 2018
    Lancashire
    575
    16
    Quote Originally Posted by Shadow Lord View Post
    Its smoother. It was either that, or a great big smooth patch on the side which stood out like a sore thumb. The full matt paint goes a long way to making it look ok.
    Current fleet
  9. #49
    Quote Originally Posted by Gary C View Post
    Sorry, I wasn't very clear. I am not talking about the orange peel. I am talking about the general feel of the paint. The original paint is "slick" for the lack of a better word. Hand slides over it. I feel like the latex paints, even when I spray with a gun, tend to be "rough". I am wondering if the paint in the can or mixing it with the hardener made any difference.
  10. #50
    May 2018
    Lancashire
    575
    16
    Hum, get what you mean. Despite the bumps, the original is almost 'slippy'. This feels more 'matt'. I have used cellulose paint and you cant get it mixed with different Matt levels, so that might help. I have also found some Stone Effect spray paint that looks as if it will produce the same texture, but to be honest it looks fine as it is.
    Current fleet
