Results 1 to 8 of 8
Thread: Software which can use 8087/80287 coprocessor?
    Default Software which can use 8087/80287 coprocessor?
    Hello, is somewhere some list of software, which can use 8087/80287 coprocessor? I know only autoCAD.
    4,516
    The previous discussion http://www.vintage-computer.com/vcfo...p/t-38292.html covers a good swath of software that used the early Intel numeric coprocessors.
    Fractal programs are the best choice for showing off how amazing having an 8087 is. Fool everyone into thinking you have a 386.
    Feb 2012
    Northern Nevada
    686
    Falcon 3.0 supported the 80287, if I recall correctly. It enable a more accurate flight model...
    Nov 2003
    Plattsmouth, Nebraska USA
    1,028
    Lotus 1 2 3.
    Rick Ethridge
    Oct 2014
    near frankfurt/m, germany
    981
    How about the several versions of MS Flightsim? Or Stuntcar-Racer and other early 3D stuff?
    Dec 2014
    The Netherlands
    2,024
    Quote Originally Posted by HoJoPo View Post
    Yup, I had an IIT387SX in my 386SX-16 at the time, which made Falcon a lot faster. I believe it also improved some graphics.
    Dec 2014
    The Netherlands
    2,024
    Most 3d games did not use the FPU at all.
    For one, most people did not have an FPU anyway, and including FPU code with an emulator was much slower than optimizing the code with fixedpoint integer.
    Secondly, early FPUs were quite slow, so even if you had one, it was often faster to use fixedpoint anyway.
    You can see the turnaround point when the Pentium arrived. Descent was still optimized for 486, and avoided the FPU.
    Quake embraced the new fast, pipelined FPU in the Pentium. Worked great when you actually ran it on a Pentium, but the 486 choked on it.
  8. Default
    Lotus 1-2-3 is a spreadsheet program from Lotus Software (now part of IBM). It was the IBM PC's first "killer application", was hugely popular in the 1980s and contributed significantly to the success of the IBM PC.
