Results 11 to 20 of 26
Thread: Apple ][ e need help: can't load programs from drive
    Quote Originally Posted by billdeg View Post
    I have sure learned a lot since then.
    Did you ever get that drive working?
    Nov 2003
    Landenberg, PA USA
    3,798
    yes. I got the system from a flea market, it was in the dirt. Frankly it was a miracle that it powered up at all. I cleaned it for a couple hours, I recall, before powering on. I still have the system. It's not pretty but it works.
    @ BillDeg:
    Web: vintagecomputer.net
    Twitter: @billdeg
    Youtube: @billdeg
    Unauthorized Bio
    Default got it to work
    after messing around a bit I got it to work. Is there a way of copying files from one disk drive toanother?
    Quote Originally Posted by jjenks View Post
    Not directly, the way you can with a DOS COPY command. If the file is BASIC, you can LOAD it, swap disks, then SAVE. If it's binary data (and will all fit in memory at once), and you know exact start address and length, you can BLOAD, swap, and BSAVE. Otherwise you have to use a disk copy utility of some sort.
    Nov 2003
    Landenberg, PA USA
    3,798
    the boot disk has a copy utility. dcopy I think it's called. I was just using it two days ago.
    @ BillDeg:
    Twitter: @billdeg
    Youtube: @billdeg
    Unauthorized Bio
    Mar 2004
    Manitoba North of 50 degrees Latitude
    1,284
    [QUOTE=Rubywand;2153]You can find some info on connecting the drive cables and getting started in the Apple II FAQs at ...
    http://home.swbell.net/rubywand/A2FA...NHALL.html#020
    Hmmm. That must obviously be your FAQ and not the FAQ withdrawn by the onetime moderator of the A-II with his Compuserve compadres, who was in a snit over pirating of his A-II Wolfenstein and general rebellian against his reign. Hee ! Somewhere on one of my computers I have that original FAQ and have considered making it available on a Russian Blog. :^))
    The A-II newsgroup had to be one of the nastiest of Usenet history. A war-zone.
    Good to see you're still active.
    Lawrence
    Economics isn't a real science. It's an evil art designed for the rich.
    Sep 2007
    You know, it just slipped my mind!
    112
    "The Topic that Came Back from the Dead"... Coming to a theater near you!
    My apple ][e looks great and it even boots like a charm. When I got it at the VCF last year, I had the one and only Trixter actually type some basic on it ("Docter Who Rocks!" on loop I think), It was great.
    Wow... this is an old post, but hey... if you plug the drive cable in backwards on a 5.25" disk you most likely have blown the 74LS125 chip inside the drive itself.
    RJ
    Default spectra light software for apple II or mac
    I have docs and hardware but no software. Can anyone help ?
    jjenks r u around?
    Spectra Light CNC software.
    Thanks
    Fred
    Nov 2003
    Landenberg, PA USA
    3,798
    Yes. Do some reasearch first.
    @ BillDeg:
    Twitter: @billdeg
    Youtube: @billdeg
    Unauthorized Bio
