Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: replacement Lamp?
  1. #21
    Okay, another old thread that I'm resurrecting.
    Did anyone find replacement lamps for the hard drives?
  2. #22
    Quote Originally Posted by Alphasite View Post
    I seem to recall that I did replace the bulb, but I'll need to check the drive tonight to see if I can refresh my memory about what I did. It's been too long since I've done anything with it to remember the details.
  3. #23
  4. #24
    Thanks!
  5. #25
    Thanks for sharing the part number! I'm ordering some to have on hand, too. Now that I re-read the thread and took a look at my 15M hard drive, I don't think I've had to replace those bulbs yet after all.
  6. #26
    The pins are a little too close together, but bend them a tad, then they work fine. I replaced all of the bulbs good or bad, just because they originals looked pretty bad off or were out.
  7. #27
    Feb 2011
    Eugene, OR
    1,647
    5
    Sorry for my ignorance, but a while ago, my neighbor from the apartment next door they out a Very nice Marance (?) with only a couple near the right side..Because the voltages to the lamps were virtually identical to LED’s. Doing a direct install of different LEDs’to replace all of the lamps. The amplifier looks better than new, plus I found that the backlit panel, (I changed these lamps with LED’s too) is much much cleaner looking and definitely brighter.
    The job was simple enough that I replaced the lamps in just over an hour.
    You know? Looking at the sockets In your pics look almost identical to the ones i re-worked. When assembling mine, I used regular plastic cement to complete the replacement. Gluing in the LED’s makes them much more stable, and solid.
    Hope this helps. ope you have a great holiday season.
    Thomas
    Wanted: - Complete SERIES ONE TRS-80, IBM 5170 AT, Original authentic IBM 5100 Portable, IBM 5151 Monitor. Also looking for Packard Bell 75Mhz computer, Commodore Pet w. Built-in cassette drive, amber 12 CRT, Mac SE-30 hard disk to replace the bad drive currently installed, TRS-80 Coco series 1 upgrades including memory, IBM PC 5160 compatible CD ROM.
  8. #28
    May 2006
    Hamilton, Ontario, Canada
    3,714
    If it helps, these things were referred to as "grain-of-wheat" bulbs and seem to be readily available on FeeBay in a variety of voltages.
    Legacy Computers and Parts
    Sales of, parts for, and repairs to, Vintage and Legacy computers.
  9. #29
    Does anyone know of a source for compatible power switches for the hard drives? I have one that someone yanked out and hacked (probably didn't have the key) and I'd like to replace it to keep it stock.
  10. #30
    If I recall correctly, this is the key switch that I used to replace the one in my 15M drive unit which came without its key.
    https://www.mcmaster.com/#7278k13/
