Page 14 of 14 FirstFirst ... 41011121314
Results 131 to 134 of 134
Thread: ASUS A7N8X-E Deluxe
  1. #131
    Sep 2008
    SE MI
    4,126
    6
    Wing Commander 4: The Price of Freedom
    Found WC4 on Gog today for $1.49 USD. The download comes with Gog's Galaxy version which is compatible up through W8. The 6 'off-line' (install.exe & BINS) files work for the XP & Vista installations, and there is even a DOS version in the mix. The install routine had a small hitch at the front end and I just told it to ignore the file and installation was completed without further incident. There are no setup options, however it soon became evident that the game should be played with a joystick. I'll need to dig my Thrustmaster out to play this thing right. This game is a real beauty and fun to play, however, the lead in with Mark Hamill is a little tedious. Another plus is that download offers the complete set of documentation.
  2. #132
    Sep 2008
    SE MI
    4,126
    6
    PCIe to PCI Adapter
    The PCIe to PCI host adapter is now here as well as the SATA 3 adapter. As summer is winding down, hopefully I can find some time for the A7. I will be attempting to install W7, once again, on a 120 GB SSD via the new hardware. Worst case scenario is that it won't work and I'm out about $40 in hardware costs. If anyone has successfully installed W7 on the A7 with a SSD recently (not an IDE), I would like to here from you.
  3. #133
    1,638
    If your janky adapter setup doesn't work, I recommend the SATA to IDE adapter I mentioned earlier. I've had a chance to test it on some Pentium 4 and Athlon XP boards and they recognized both the SSD I had and regular SATA HDDs.
  4. #134
    Sep 2008
    SE MI
    4,126
    6
    I'll definitely keep that in mind and thanks for the tip.
