Results 1 to 2 of 2
Thread: Fabri-Tek MP-12 Industrial PDP-8 Clone
    Default Fabri-Tek MP-12 Industrial PDP-8 Clone
    A handful of folks have a few of these Fabri-Tek MP-12 industrial control computers, including another user here, conmega. Together, we've been working on reverse engineering bits and pieces (software and hardware) to get these doing something useful.
    First thing's first: pictures!
    Here's a summary of what we've done so far:
    1. These systems date to 1975 or so, but were used up into the 2000s for controlling movie film developing tanks, as I understand it. Thus, powering them up was as easy as plugging them in...almost. There's no obvious spot for power, but upon removing the cover, it became clear that it would obtain power via the paper tape reader and I/O box with a V.35 connector. So instead, we've hot-wired in a line cord across the transformer in the main box. 120VAC power is transmitted over a straight-through DA-15 connector...kind of scary, but I guess it works.
    2. I wrote some very simple code to test the front panel operations. Turns out that while the machine runs, the front panel lights only show what's on the bus, so watching the accumulator is not possible. You can single-step, though. Also, to show how limited the front panel really is: the deposit operation doesn't increment PC automatically. So if you're having to toggle in much, it's address, load, data, load, and repeat. However, if you're clever and not toggling in too many JMP, JSR, SKP, or other such operations that change the PC, you can use single-step to increment the PC.
    3. Just the Fabri-Tek by itself is kind of lame. It has no I/O without the paper tape reader and I/O box connected via the DA-15 cable (using a high-speed synchronous serial connection with a bunch of 7400-series shift registers). It also only has 4k of core (and a dash of ROM at the top). The ROM is a very basic paper tape loader, dare I say, even more basic than DEC's RIM loader. It took quite a while for me to fully understand how it worked, but I am finally there now. The ROM's used are 512 by 4 bit bipolar PROMs. It would appear as though when the word is equal to 7777 octal, core is referenced instead. Otherwise, the ROM values are read. Writing to the location does nothing, best I can tell. Here's the disassembly listing of the ROM code:
        1        7755  *7755
        2 07755  0000  BEGIN,  0
        3 07756  7755  TEMP,   BEGIN           /NOT IN ROM
        4 07757  7602          CLA HLT         /7602
        5 07760  7755  ADDR,   BEGIN           /7755 STARTING ADDRESS?
        6 07761  1360  START,  TAD ADDR        /1360 GET STARTING ADDRESS?
        7 07762  3356          DCA TEMP        /3356 SAVE TEMPORARILY
        8 07763  6012  LOOP,   6012            /6012 ADVANCE TAPE
        9 07764  7106          CLL RTL         /7106
       10 07765  7006          RTL             /7006
       11 07766  7006          RTL             /7006 ROTATE SO BIT 0 IS IN BIT 7, BIT 4 IN BIT 11, ETC.
       12 07767  6015          6015            /6015 READ TAPE AND SKIP
       13 07770  5367          JMP .-1         /5367
       14 07771  7420          SNL             /7420 SKIP IF LINK IS SET (BIT 6 OF PAPER TAPE IS SET)
       15 07772  5363          JMP LOOP        /5363
       16 07773  3756          DCA I TEMP      /3756
       17 07774  2356          ISZ TEMP        /2356
       18 07775  5355          JMP BEGIN       /5355
       19 07776  7776          7776            /NOT IN ROM
       20 07777  5361          JMP START       /5361
       21              $
    Notice there are two locations there that are "NOT IN ROM." These are unprogrammed in the PROM, allowing for the system to read and write from core in those locations. Understanding what 6012 and 6015 did were the tricks, though. I wrongfully assumed that the reader was compatible with the high speed reader that DEC used or the IOmec reader, but instead, this has its own instructions. 6012, instead of reading the buffer like on a PC8E, advances the tape one byte. What should've clued me in that this wasn't DEC was that 6015 isn't used on the PC8E except in perhaps very rare circumstances, as it's a combination of clear flag and skip if flag. On the IOmec reader, it skips if the end of tape flag is set. In the Fabri-Tek, 6015 reads the buffer and skips if the reader is ready, apparently.
    Once that was figured out, it became clear that this was similar to the RIM loader, but only to a point. Starting at 7777, the loader jumps immediately to START, where it loads 7755 into the AC, then deposits into a temporary address. It then advances the tape, clears the link and rotates an empty AC around 6 times. Then it reads the buffer and will jump back to LOOP since the link is not set. It then repeats, advancing the tape, clearing link, rotating accumulator, and reads again. If the first byte it read in had a 1 in the 6th bit, the link will now be 1, causing it to skip. The second byte should only have data in the bottom 6 bits (bits 0 through 5, if you will) so that you don't disturb the upper 6 bits in the AC. This value is then dumped into the address indirectly referenced by TEMP, which as we loaded initially, is still 7755, with the label BEGIN. The temporary address is then incremented and now points to itself: location 7756 contains 7756, and location 7755 contains the word constructed from the first two bytes on the paper tape.
    Here's where things get funky: the program jumps to 7755 (BEGIN), not 7763 (LOOP) as one might expect. I was very confused; why would it want to jump to the word it just deposited from paper tape? Unless that first word is a jump instruction, you're not going to get very far.
    Well, that's exactly what I decided to do. Obviously this loader is pretty useless by itself, but maybe I can find a way for it to load a custom BIN loader that will support checksums and other niceties. If the first instruction on paper tape is 5363, you will JMP BEGIN (5355) at location 7775, then JMP LOOP (5363) at location 7755 (BEGIN). That will allow the loader to read another two bytes off the tape, construct them into a word, and deposit into the TEMP location. As you've probably figured out, TEMP holds the pointer to where the next word will be stored. Since TEMP is pointing to TEMP, this next word should be the starting address of your program (minus one; there's an ISZ TEMP prior to the deposit of the next data word). Now we're onto something! You can keep loading data sequentially with this manner. But how do you stop? Well, if you want, you can put some unpunched trailing tape which will never deposit anything since bit 6 isn't punched, or you can put your code up at the very top of the 4k field such that your last instruction overwrites location 7755 with a HLT or JMP instruction; when the loader issues JMP BEGIN, it will now be jumping to your new instruction that you loaded at 7755, letting you break out of the loader. Now there's an idea for the BIN loader! The BIN loader is generally put right under the RIM loader anyways, so the last instruction on the tape could be a JMP to a HLT instruction immediately before the normal start of the BIN loader.
    See that location near the top: 7776? It never got used. I decided to use it for the BIN loader; turns out DEC did too. 7777 was the starting address for the BIN loader (similar to here, it jumps to the actual start of the program), but unfortunately, that part's in ROM, so it can't be (easily) changed. The CLA HLT instruction at 7757 was never really used either, but that's alright. Not very important, best I can tell.
    I've since written a simple C program (available upon request) that reads a DEC BIN or RIM tape and outputs a Fabri-Tek RIM format tape, adding the required JMP LOOP instruction and organizing the data so that the sequential loader puts it in the right spot; sure beats editing tapes by hand in a hex editor. I've found I can't mix hex and octal in my head very easily. These tapes are best edited in an octal editor, which I haven't really found. My workaround is a Vim script that converts the buffer from binary to octal digits and back. A little tedious, but not too bad.
    4. All this to say, here's the custom BIN loader I wrote based on DEC's original BIN loader:
        1              /BIN LOADER FOR FABRITEK
        2              /KYLE OWEN - 4 DEC 2015
        3
        4        7653  *7653
        5 07653  0000  SWITCH, 0
        6 07654  0000  CHAR,   0
        7 07655  0000  CHKSUM, 0
        8 07656  0000  ORIGIN, 0
        9
       10 07657  0000  BEGG,   0
       11 07660  3253          DCA SWITCH
       12 07661  4304          JMS READ        /GET CHAR
       13 07662  1317          TAD M376        /TEST FOR 377, SUBTRACT 376
       14 07663  7750          SPA SNA CLA     /DON'T SKIP IF BIT 0 IS SET
       15 07664  5270          JMP .+4
       16 07665  2253          ISZ SWITCH      /YES, COMPLEMENT SWITCH
       17 07666  7040          CMA
       18 07667  5260          JMP BEGG+1
       19 07670  1253          TAD SWITCH      /NOT 377
       20 07671  7640          SZA CLA         /IS SWITCH SET?
       21 07672  5261          JMP BEGG+2      /YES, IGNORE
       22 07673  1254          TAD CHAR        /NO, TEST FOR CODE
       23 07674  0313          AND MASK        /TYPES
       24 07675  1343          TAD M200
       25 07676  7510          SPA
       26 07677  2257          ISZ BEGG        /DATA OR ORIGIN
       27 07700  7750          SPA SNA CLA
       28 07701  5657          JMP I BEGG      /DATA, ORIGIN OR L/T
       29 07702  7402          HLT             /IF FIELD SETTING, HALT!
       30 07703  5320          JMP BEGIN
       31
       32 07704  0000  READ,   0
       33 07705  6012          6012
       34 07706  6015          6015
       35 07707  5306          JMP .-1
       36 07710  3254          DCA CHAR
       37 07711  1254          TAD CHAR
       38 07712  5704          JMP I READ
       39 07713  0300  MASK,   300
       40
       41 07714  4345  BEND,   JMS ASSEMB
       42 07715  7041          CIA
       43 07716  1255          TAD CHKSUM
       44 07717  7402  M376,   HLT
       45 07720  4257  BEGIN,  JMS BEGG
       46 07721  5320          JMP .-1
       47
       48 07722  3255  GO,     DCA CHKSUM
       49 07723  1254          TAD CHAR
       50 07724  3376          DCA WORD1
       51 07725  4304          JMS READ
       52 07726  3354          DCA WORD2
       53 07727  4257          JMS BEGG
       54 07730  5314          JMP BEND
       55 07731  4345          JMS ASSEMB
       56 07732  7420          SNL
       57 07733  5341          JMP MEMFLD
       58
       59 07734  3256          DCA ORIGIN
       60 07735  1376  CHEX,   TAD WORD1
       61 07736  1354          TAD WORD2
       62 07737  1255          TAD CHKSUM
       63 07740  5322          JMP GO
       64
       65 07741  3656  MEMFLD, DCA I ORIGIN
       66 07742  2256          ISZ ORIGIN
       67 07743  7600  M200,   7600
       68 07744  5335          JMP CHEX
       69 07745  0000  ASSEMB, 0
       70 07746  1376          TAD WORD1
       71 07747  7106          CLL RTL
       72 07750  7006          RTL
       73 07751  7006          RTL
       74 07752  1354          TAD WORD2
       75 07753  5745          JMP I ASSEMB
       76
       77        7776  WORD1=7776
       78 07754  0000  WORD2,  0
       79
       80        7755  *7755
       81 07755  5317          JMP BEGIN-1
       82
       83              $
    I opted to keep some of DEC's comments, but got lazy when retyping out parts and didn't include all of them. DEC did a very nice job with this loader; it's very efficient. I made it more efficient by stripping the field support (the Fabri-Tek may never get extended memory, or at least not anytime soon). There's also only a high-speed reader here, so I stripped the low-speed code as well.
    The process for loading the BIN loader is super simple: load the tape into the reader, reset the Fabri-Tek to clear AC, load 7777 into PC and run. The BIN loader is quickly loaded, and upon completion, the loader jumps to the HLT instruction prior to the start of the BIN loader. Take out the BIN loader tape, put in a BIN-formatted tape, and run. When the trailer is encountered, the checksum is verified in AC (should show zero), and you should be ready to roll with your newly-loaded program.
    5. We also deciphered some more instructions for the I/O box: 6052 and 6053 read the buttons and switch on the front of the reader box. 6070 through 6073 allow you to turn on the seven 7-segment displays on the front of the unit. Each instruction except the lasts updates two at a time. They use a 7442 to drive the displays, so you only get 0-9, garbage, and blank. Too bad they're not connected directly to shift registers so that you could turn on individual segments and make some letters too. 6074 writes to 8 open-collector outputs on the back, and 6075 controls two relays. We've seen potential references to device code 06 and other potential instructions for 05 and 07, but further investigation is required before we can determine what they do.
    Think that's about it for now...trying to track down a V.35 connector so I can feel a bit better about the power situation, and eventually I'll port my SPI-controlled LED string program to the machine so I can have something to impress my family members with in a couple of weeks.
    Big thanks to conmega for his help in reverse engineering parts of the hardware for better understanding of the system, and for dumping the ROMs, among other things!
    Kyle
    Jan 2010
    Central VA
    4,797
    I saw conmega's machine at the Festivus get-together this weekend -- super cool machines! IMO, more interesting than seeing a regular DEC PDP-8!
