Results 1 to 9 of 9
Thread: ABIT 386 AMI BIOS needed!
    Exclamation ABIT 386 AMI BIOS needed!
    Hey guys after scouring the internet for days trying to bring a computer from my childhood back to life, I decided to stop by here and see if someone can help me. I have an 386 motherboard with a corrupted BIOS chip, and I'm trying to locate a new file to program to a new chip to bring it back online. Using my chip programmer, I have managed to read the chip and extract the identification code from the bios that would normally display in the lower left hand corner of the screen.
    30-400-ZZ1247-00101111-050591-PEAKDM
    The board uses 3 CHIPS and Technologies chips, numbered as follows...
    F82C351, F82C355, F82C356
    I believe the board is an ABIT FU325/FU333/FU340.
    Thanks guys!
    I attached a bios file with the ID 40-0200-DN1429-00101111-050591-PEAKDM_B
    It is from a 486 board with the same chipset.
    Chips_Peak-DM.bin.zip
    (binary file, just remove the ".zip" extension)
    I own the 386 board in question. After work I can upload the ROM.
    *edit*
    Here you are:
    Attached Files Attached Files
    V'Ger XT
    6,526
    6,526
    Quote Originally Posted by Anonymous Coward View Post
    *edit*
    Here you are:
    I have added it to http://www.minuszerodegrees.net/at_c...clone_bios.htm
    You guys are awesome! I tried both BIOS files, and both work great. It was awesome to see the board back to life after being stuck in a closet for so many years. I was hoping the 486 version of the BIOS might have LBA support for larger drives, but no luck. Does anyone know if anyone made a BIOS for this chipset with LBA support?
    Quote Originally Posted by Rodney Hershkowitz View Post
    You might want to look into using XTIDE Universal BIOS.
    Since you are the original owner the FU340, by chance would you happen to have the user manual for it?
    V'Ger XT
    Sep 2008
    SE MI
    4,485
    6
    Quote Originally Posted by diodenmann View Post
    Diodemann:
    Thank you very much.
