Page 14 of 14 FirstFirst ... 41011121314
Results 131 to 140 of 140
Thread: IBM/C128 CGA conversation, capture, and VGA display success stories
  1. #131
    Jun 2015
    Sioux Falls SD
    269
    I just received the Monotech EternalCRT converter. Only took 11 days from New Zealand. I connected it to a Samsung T220 22" LCD monitor/TV with a VGA cable, then to the CGA output of the IBM 5150. Out of the box, it was poor, with a lot of flickering pixels in the characters. Adjusting the Phase control sharpened it up. Colors were ok, but haven't tested extensively. I actually got better character formation in Hercules mode instead of CGA, with higher pixel density. In CGA mode, it looked very similar to the IBM 5153 display, only a lot bigger.
    Considering the prices for VGA cards on ebay, the $120 for this box is reasonable to me, as I can always switch to the 5153 display without pulling cards.
  2. #132
    Quote Originally Posted by lafos View Post
    Considering the prices for VGA cards on ebay, the $120 for this box is reasonable to me...
    I must have missed your point 'cause I just looked on eBay and found dozens of VGA cards that sold for $10 - $35.
    Additionally, I have a few for sale around that same price range.
  3. #133
    Jun 2015
    Sioux Falls SD
    269
    Guess I missed those.
  4. #134
    If I had known you were looking I would have let you know what I have.
  5. #135
    So I have a working design for CGA to VGA. Currently it does linedoubling only but I am looking at making a full frame de-interlacing version.
    You get a pretty damn amazing picture if I do say so myself.
    The slight issues you can see are due to the monitor sampling of the output NOT my sampling of the input I tried it on a CRT VGA monitor and it looked pixel perfect. The monitor used to display it make a great difference. If I manage to make a full frame deinterlacing version I might tweak the VGA output mode to be more compatible too.
    It will cost less than all other solutions that end in VGA currently when finished and on sale.
  6. #136
    May 2016
    Fairfield, Ohio
    418
    8 bit or 16 bit?
  7. #137
    16-bit
  8. #138
    Many 16-bit VGA cards will work fine in an 8-bit slot, though.
  9. #139
  10. #140
    Mar 2006
    Massachusetts, USA
    1,880
    Quote Originally Posted by Pyrofer View Post
    Can we please just have something that goes from one digital format (CGA/MDA/HGC/PCJR/TGA/EGA) to another digital format (DVI/HDMI)? Everything that converts to VGA goes to analog, which introduces quality loss and a second analog to digtal conversion which introduces more quality loss. VGA is little more than a crutch.
    My Retro Computing and Vintage Gaming Blog : http://nerdlypleasures.blogspot.com/
