Results 1 to 3 of 3
Thread: IBM System/36 5364 how to do a system backup to diskette
    Feb 2012
    Fort Walton Beach, Fl
    508
    Default IBM System/36 5364 how to do a system backup to diskette
    While comparing receiver cards, I broke out the 5364 System/36. I have not backed it up since I got it working.
    How do you perform a full system save where you can IPL and restore the system from Diskette.
    On our AS/400 it's Go Save or SavSys and then choose what options you want.
    Thanks,
    Jimmy
    Aug 2009
    Oslo, Norway
    1,346
    3
    I don't know. But the manuals are on Bitsavers: www.bitsavers.org/pdf/ibm/system36/
    Torfinn
    Feb 2012
    508
    Thank you, I thought I could not find the command in the manual, but it appears there is no similar command in SSP. I had copied the microcode to a floppy with the INITDIAG command, then backup up the #Library, then my loaded modules with the xxxSAVE command.
