Results 1 to 10 of 24
Thread: IBM RT data retreival with QIC-02 tapes
    Feb 2012
    New Zealand
    2,657
    Default IBM RT data retreival with QIC-02 tapes
    I just need a nudge in the right direction here.
    So I've got the RT with AIX 2.1 - it has commands like backup/restore and tar etc which I can use to backup files to tape and I've done so in the past successfully.
    But now I've got another 150MB tape drive + QIC02 controller coming which is capable of reading the same 6150 QIC tapes and it has a normal 8 bit ISA adapter with an address select switch which I could easily put in a general IBM clone (in fact it appears it came from a Compaq originally in 1990). What I want to do is read the contents from my AIX tapes, on to a normal PC, so I can get files off the RT - there is a lot of neat stuff on it which isn't published including the source code for a VGA driver for AIX 2.1 (for a specific card unfortunately, but quite neat nonetheless).
    Ideally I would use ethernet, but my card gave up long ago.
    So if I'm setting up a PC system (and I have almost limitless options here) - what OS / hardware combo would you recommend?
    What method would you recommend?
    Any advice / ideas?
    Anyone got a spare RT ethernet card :P ?? That'd save me a lot of tape work!
    33,692
    Are you wondering how to support the old QIC controller? If so, NetBSD still has code for supporting the old ISA QIC controllers; you may have to rebuild the kernel however. You might also try a very old Debian distro, such as Woody to get that support.
    Feb 2012
    New Zealand
    2,657
    Thanks Chuck, that gives me a starting point for a build. I did a bit of google work, and found my specific model was supported in the MTIO module which was pretty neat - have a Duron sitting here doing nothing which should be ideal for a Debian Woody or Potato install.
    However seems to be a bit of a bust, not only is there no capstain left, but despite dismantling it and giving it lots of WD40 love - I can't get the eject mechanism to work properly. It works a lot nicer now than it did, but when it goes to eject the "window" ends up hitting the heads. It's a nice setup - push in once to load, push again to unload, but there isn't enough movement/pressure to push the heads that little bit further out of the way. Just frustrated at the moment, cost me over 50US, and if I buy another at the going rate of 80-100 US - probably going to be in the same boat - manually fixing a capstain and crossing my fingers nothing else is broken.
    On the upside, I probably have a good controller, (Wangtek 0775) and another 6150 tape cartridge.
    If anyone knows of a common eject fault issue that I probably have with a Wangtek 5150EQ, please let me know
    33,692
    That's a problem that's begun surfacing in spades in the past few years. I've got a QIC-36 Wangtek drive here too and its capstan has gone south. The eject still works okay, though--I don't know if it's the same as yours, however.
    In a pinch, you can try one of the older Tandberg SLT drives with a SCSI interface. Some of them will honor the older QIC formats.
    Feb 2012
    New Zealand
    2,657
    Yeah I had it with my IBM 6157-002 as well, but by chance somebody was selling brand new full capstan assemblies at the same time on ebay - so I got lucky there.
    Thanks for the Tanberg reminder - I've got two pulled from an RS/6000 setup around somewhere. I didn't even think of these because for some reason in my head I thought they weren't compatible. I'll dig them out and look up the model numbers - fingers crossed.
    Feb 2012
    New Zealand
    2,657
    Ok well it seems my other drives are in my storage unit, so probably wont poke those until Saturday. But I did find the tapes it came with, and they're QIC525. So I'm guessing here, but probability looks good for them reading and maybe writing QIC150. Tapes are labelled as backups of someone's business documents from 1997 - surprised they got donated to a charity.
    In other news, I fixed the eject mechanism on the Wangtek 5150EQ - there is a bar underneath that runs the length of the drive, overtime it loses a bit of strength and requires adjustment - Wangtek was nice enough to actually have a screw down block which is used to make the adjustment, so now I can pop tapes in and out.
    Have been looking at guides online of capstan repair, my favourite/looks the easiest might be heatshrink tubing - possibly with a touch of adhesive and multiple layers (the gap is quite large). If it wears too much, I'll do a ring of better material on the outside. Unless I can find the actual measurement, will be a bit of guesswork on size. Any tips welcomed on that, probably wont be until the weekend again.
    33,692
    It might be worthwhile to have Terry rebuild one. He does good work.
    Feb 2012
    New Zealand
    2,657
    I noticed him mentioned in an old thread when I was googling, but didn't think it was still in operation. That's brilliant, thanks for the link.
    He has a photo of Wangtek 5525ES drive capstans he's done too which look identical to mine [ except my rubber is 100% gone ].
    Of course if I go that route I may be waiting two months (living in NZ etc), but if the Tandberg's get the job done anyway, then that wont matter. If the Tandberg's are faulty for the same reason, I might do one home job, and then see if he can do me a batch. I've also got a 23MB QIC drive in the AT&T 3B2-400 that's no doubt long gone as well.
    Feb 2012
    New Zealand
    2,657
    The Tandberg (actually it's a legit IBM 7207 external unit I had) seems to have a capstan in good shape, so tonight I'm building a Duron 800 running Debian Woody, and will try it out.
    On the topic of the original QIC drive from Wangtek, I picked up a tip that somebody mentioned 5/16" ID (5/8" OD) fuel hose as a candidate for the Wangtek 5000 series drives, and it looks pretty good!
    I'll try it out at some point to confirm, it certainly engages the tape perfectly but whether or not I've created a tape speed issue needs to be checked.
    33,692
    The problem with neoprene hose that I found was that it's far from really round. Maybe you'll have better luck. I've considered using some Tygon hose as a possibility.
