Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 32
Thread: identifying this XT clone motherboard~
  1. #21
    Sep 2013
    Ruston, Louisiana, United States
    62
    where can i get the faster chips? ^^
  2. #22
    Sep 2013
    62
    what are the faster chip's names?
  3. #23
    Sep 2013
    62
    any tips? i failed to over clock it ><
  4. #24
    May 2009
    Connecticut
    4,730
    Maybe you could describe what you have tried? It could be a bit frustrating to have suggestions to do what you already did.
    You may be running in to the problems of board design. Few XT clone boards could handle 12 MHz and even fewer expansion cards worked when the bus was pushed that fast.
    Edit: Maybe this web page can help. http://www.malinov.com/Home/sergeys-...ts/sergey-s-xt It describes an expansion card holding an XT equivalent system that can run at 13.2 MHz. Very different from your classic motherboard design but may provide some ideas on high speed clock generators and the like depending on how hard you intend to work on the issue.
  5. #25
    Sep 2013
    62
    ah i installed equivlent chips of the mentioned above and use faster clock crystam from 24Mhz to 32MHz and 48MHz
    none of the faster crystals worked
  6. #26
    Sep 2013
    62
    IMG_20160525_083643623.jpgIMG_20160525_083657289.jpg here is the current setup of my attempt to over clock (this works)
  7. #27
    Jan 2009
    coastal New England
    298
    Oh, sorry for being late to this thread, I've been away for a while. I have the same motherboard, see my thread from last year http://www.vcfed.org/forum/showthrea...bay-components
    The XT I built around it is pretty tricked-out now, with full 1.44M floppy support, IDE and VGA. I never thought about overclocking though. It's a good board and I'm happy with it.
    Best part, I have the board's manual. If you want I can scan and post it.
  8. #28
    Sep 2013
    62
    Quote Originally Posted by jh1523 View Post
    please do!!
  9. #29
    Jan 2009
    coastal New England
    298
    Quote Originally Posted by sparky4 View Post
    please do!!
    Sorry didn't see the reply until today. I don't come here often. I will when I get back from vacation (I'm currently away from home and won't return until the 3rd week of July).
  10. #30
    Nov 2012
    Buenos Aires, Argentina
    31
    Hello, it looks like this motherboard https://th99.bl4ckb0x.de/m/U-Z/33657.htm
Tags for this Thread
