Results 1 to 10 of 13
Thread: VGA Cards that work in 5150 board.
    Sep 2009
    Coventry, UK
    119
    Default VGA Cards that work in 5150 board.
    Hi all,
    I thought whilst I had my vintage PC gear out I'd test the 8 and 16 bit VGA cards I have in my recently repaired 5150 board to see if they worked.
    Below are pictures of the cards that work.
    Modem7, if you want to pinch these for your compatibility list feel free.
    The first two are 8 bit cards, I have a couple of the WDC ones actually built into machines and they work well.
    The first one has "Copyright WAVE Mate Inc", but no model no or anything, main chip seems to be Intel.
    This one is a WDC board, There are two similar boards on http://www.minuszerodegrees.net/ that appear to be the 16 bit version of this.
    Bioes for the above two : 8bit.zip
    The next bunch are 16 bit cards all of which seemed to work in their default configuration.
    These two are marked OCTEC, one has a Triedent 8800 and the other a Trident 8900 chip
    Bioses : 16bit-octec.zip
    16 bit bioses 16bit.zip
    This last card would only work with a V20 CPU so I suspect it uses 186/286 instructions.
    Marked Wang 3050
    Bios 16bit-wang.zip
    Cheers.
    Phill.
    Sep 2009
    Coventry, UK
    119
    And here's the BIOS files....
    Humm for some reason it won't let me upload the zip file with the bioses in.....
    Cheers.
    Phill.
    2,895
    This forum won't attach anything larger than 99k. Perhaps split the zips up.
    You might also try tinyupload instead.
    Also, do you have the exact names of each of these cards?
    I also have VGA Card (OAK 16bit ISA / WD 16bit ISA).
    I think most of 16bit ISA VGA works on IBM PC 5150 / 5160 motherboard.
    2,895
    Many, yes. But not all, and it gets frustrating when trying to fix a computer and you don't know if a card is really supposed to work.
    For reference, another thread on the subject:
    http://www.vcfed.org/forum/showthrea...-ISA-VGA-cards
    And another list here:
    http://minuszerodegrees.net/5150/vga/5150_vga.htm
    Quote Originally Posted by fs5500 View Post
    I know that's not the case.
    I have a stack of 16-bit ISA VGA cards that don't.
    And, I have several that work fine on the 5160 but not at all on the 5150.
    2,895
    Stone, have you documented these somewhere? It would even be good to have a list of cards known NOT to work.
    There was a thread recently where someone else had a card that works on a 5160 but not 5150. But I still find that odd as the only significant difference I am aware of is a 5150 reserved range of I/O ports (that cause problem for IDE related stuff). Of course the first rev 5150 BIOS doesn't count because a later version is a well known minimum requirement.
    Sep 2009
    Coventry, UK
    119
    That seems insane, especially considering the size of the image files
    Cheers.
    Phill.
    2,895
    If you look closely you will notice that all large image attachments are recompressed by the forum software so they are about 99k. With JPGs that is usually not too noticeable, but it messes up large PNGs. Just re-download the images you posted above and look at the file size.
    I mentioned that not to long ago. (It's version 3.)
    I will put a list together of what I have that doesn't work on my 5160 and the card I have that does work on the 5160 but not on the 5150.
