Results 1 to 6 of 6
Thread: Ethernet and the PDP-11
    Feb 2011
    Salisbury Maryland
    765
    Default Ethernet and the PDP-11
    Ok, so I donít have enough difficult projects going on now I am thinking of a new project. A network port for my PDP-11/23 Qbus system. I see where there is a DEQNA M7504 Ethernet adapter card that will work in both 18 and 22 bit systems but I have several questions, first what operating system will support that card? , can I do it with RT-11 version 5? Or do I need a more advanced version of RT-11? What would the card appear as to the operating system? I think ďNQĒ is the device driver for Ethernet and am going to assume on the PDP-11 the device will be NQ0? And what about the external H4000 transceiver? Can I get a thick net to cat 5 adapters that will take its place or is there some other magic that takes place with the adapter? Donít want to branch into coaxial LAN at this time and would like to keep it all standard CAT 5 cables. Was thinking that a little Cisco AUI to RJ-45 would be the answer but donít know. Also what about the M7516 from the Micro Vax family?
    The goal is to install a network port on the 11/23 and use that to communicate with newer Windows systems to upload and download programs. And not have to do this thru the serial port on the CON.
    Ray F/Qbus
    4,223
    I'm not sure what the version requirements are, but there's a fairly good/complete collection of TCP/IP programs for RT-11 that are freely available:
    http://shop-pdp.net/rthtml/tcpip.htm
    Works with either QBus Ethernet card (DEQNA/DELQA). You can FTP files easily that way. Much faster and more convenient than a serial link. 2.11BSD has built-in drivers for Ethernet, and a TCP/IP stack, but you won't be running 2.11BSD on a PDP-11/23. I'm not sure if older versions of UNIX support TCP/IP on the PDP-11, I haven't personally played with them.
    As to cabling, you'll want a media converter. AUI (Thicknet) to 10baseT (Cat 5) converters are cheap, common, and available. Allied Telesis/Telesyn CentreCOM converters are probably the most common by volume, that's what the majority of mine are and they seem to be super common on eBay. If you need a tested converter and don't want to mess with eBay, PM me, I've got more than I need.
    But you can with an 11/73. What better excuse to upgrade with a M8192.
    4,223
    Quote Originally Posted by cruff View Post
    If it's an 18-bit backplane, he'll have to either upgrade backplanes or wire wrap the upper four bits. But yeah, easy upgrade if you decide you want to run 2.11BSD! I'm using a microPDP-11/73 with 2.11BSD as my main PDP-11 at the moment.
    Feb 2011
    Salisbury Maryland
    765
    Think the problem is that my brain is so small I can’t wrap my head around the fact that if I get a working network port it won’t be like a windows system where I can see and access drives online. Maybe that’s the reason for migrating to UNIX? Think an 11/73 may be in the cards at some point or perhaps drag out my MicroVAX two and look at that again. Just that it would be fun to have a way to transfer files from the old RT-11 systems to a modern system without lots of aggravation. MicroVAX won’t address some of my favorite devices like the RL or RX drives. May also revisit the process of using the PDP-11 GUI on a Windows system and seeing how fast of a RS-232 port that I can put in the 11, forget the Ethernet stuff for now. Going from modern systems at work to primitive systems at home appears to be too much of a challenge for me.
    Nov 2014
    Chicagoland
    177
    Quote Originally Posted by Qbus View Post
    Think the problem is that my brain is so small I canít wrap my head around the fact that if I get a working network port it wonít be like a windows system where I can see and access drives online. Maybe thatís the reason for migrating to UNIX? Think an 11/73 may be in the cards at some point or perhaps drag out my MicroVAX two and look at that again. Just that it would be fun to have a way to transfer files from the old RT-11 systems to a modern system without lots of aggravation. MicroVAX wonít address some of my favorite devices like the RL or RX drives. May also revisit the process of using the PDP-11 GUI on a Windows system and seeing how fast of a RS-232 port that I can put in the 11, forget the Ethernet stuff for now. Going from modern systems at work to primitive systems at home appears to be too much of a challenge for me.
    Look into the TSX+ package that S&H just released for hobbyist work. It will work on a 11/23 with 256k Memory or more. Add the Shop-PDP TCP-IP and you have a powerful combination. You get all the feel and most of software of RT-11 plus multiple windowed VT100 sessions and most programs can get 28KW of memory. You can start an FTP transfer as either host or client, while doing other work or play at the same time. The toolset includes:
    TCP/IP Network Server
    Telnet Client
    Remote TELNET Server
    Remote Telnet Port Server
    CNCT Client
    Remote CNCT Server
    Remote CNCT Port Server
    FTP Client
    FTPL Client
    Remote FTP Server
    MAIL Client
    MMAIL Client
    POP3 Mail Server
    MAILER Task
    Remote MAIL Server
    Local Printer Utilities
    Remote LPD Server
    Printer Daemon
    Remote Printer Utilities
    Remote Binary File Printing
    Remote HTTP Web Server
    Remote Gopher Server
    Remote Authorization Server
    Port Monitor Program
    Password and Authorization Files
    Client/Server Monitor
    Subdirectory Utilities
    Subdirectory Summary Utility
    All this w/o losing the fallback to basic RT11 whenever you want.
